First post, by superfury
When connecting with Dosbox, I can connect multiple times without issue. But, strangely, when connecting using UniPCemu, then disconnecting, then reconnecting(thus every second time it connects), the SLIP server doesn't seem to respond?
UniPCemu and SLIP server code:
https://bitbucket.org/superfury/unipcemu/src/ … ardware/modem.c
Look for the updateModem(timepassedinnanoseconds) for the exact function that updates the modem and SLIP server state.
It looks like the SLIP server isn't sending data over the connected TCP port when connecting every even time using UniPCemu(it doesn't seem to do that with Dosbox)?
Edit: It only seems to apply when connecting fully over the WAN, not when connecting over the LAN? Perhaps something to do with my virusscanner?
Edit: Just confirmed. Said problem only happen when accessing the server through the WAN. When using a local connection(though the local modem/network IP addresses) the issue doesn't seem to happen? Perhaps something caused by the real ISP?
UniPCemu Git repository
