PCem AMD Ryzen 3700X
Emulation of old PCs, PC hardware, or PC peripherals.
Postby Golf_GTI » 2019-8-23 @ 01:26
I change my CPU i5-4670K for AMD Ryzen 7 3700X and PCem runs the same (the same FPS in games).
Golf_GTI
Re: PCem AMD Ryzen 3700X
Postby kjliew » 2019-8-23 @ 03:21
It is great to hear that AMD had finally caught up with Intel on single-thread performance, even though this is on the 4th-gen Haswell core. What more can you expect?
kjliew
Postby robertmo » 2019-8-23 @ 06:18
according to https://www.cpubenchmark.net/singleThread.html
latest ryzen should be fastest in single core
User avatar
robertmo
Postby Golf_GTI » 2019-8-23 @ 06:40
Does PCem use only one core?
Golf_GTI
Postby robertmo » 2019-8-23 @ 08:21
Yes
User avatar
robertmo
Postby ShovelKnight » 2019-8-23 @ 08:29
Isn't faithful emulation the whole point of PCem? I mean, if you're emulating a 386, it should provide 386 levels of performance regardless of your host configuration.
ShovelKnight
Postby robertmo » 2019-8-23 @ 14:06
and if you're emulating a Pentium II it should provide Pentium II levels of performance regardless of your host configuration.
User avatar
robertmo
Postby robertmo » 2019-8-30 @ 04:58
Golf_GTI what are your results in dosbox with dhrystone?
viewtopic.php?f=31&t=33331&p=278171&hilit=dhrystone#p278171
User avatar
robertmo
Postby Silanda » 2019-8-31 @ 12:25
Mine absolutely smokes my old overclocked 3570k.
Silanda
Return to PC Emulation
Who is online
