Bochs Debugger
First post, by cookertron
Hi folks,
Has anyone had any experience with Bochs and the built-in debugger?
I would like to debug a program but don't know how to get the debugger to stop at the point the program is about to be executed.
Thanks for your help
Anthony
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 1 of 2, by superfury
This seems to give some information:
https://thestarman.pcministry.com/asm/bochs/bochsdbg.html
Searching a bit more, I also found this:
https://www.cs.umd.edu/~hollings/cs412/s02/debugger.html
Perhaps enough to get starting? It seems vbreak/lbreak is what you're searching for?
Although the main issue is figuring out what segment your program is running on, since it might be dynamically allocated(although it might be unchanging when called in a defined order, e.g. directly after booting to the MS-DOS prompt and executing it. Then, each time after booting and executing it it will be the same(assuming nothing else changes calling the program).
UniPCemu Git repository
Reply 2 of 2, by cookertron
I think what I may do (based on what you've said) is construct a routine that outputs the segment address to the terminal and assume that's where it'll be every time I run the emulator. Does anyone have any thoughts on that?
