A small assembler to practice x86
Emulation of old PCs, PC hardware, or PC peripherals.
Postby cookertron » 2019-8-26 @ 15:25
Hi Vogons,
Does anyone know of a small windows desktop program that can allow me to create a bit of x86 assembly language, run it and see how the registers are effected? It would help if it emulated a bit of memory too.
I have Turbo Debugger but I can't create code on the fly, well not without writing over actually memory.
Thank you
Anthony
cookertron
Re: A small assembler to practice x86
Postby superfury » 2019-8-28 @ 05:16
You can take UniPCemu, put it's debugger in single-step mode, then use nasm to compile a BIOS and copy it to the ROM directory, then run UniPCemu and observe the code executing by pressing numpad 2?
Afaik a compiler that allows for assembly machine code to be changed on the fly doesn't exist yet? I've never seen one at least.
superfury
Postby danoon » 2019-8-28 @ 16:02
It's not a "small windows" program, but its free. You can use the MSVC community, in a 32-bit program you can inline asm (64-bit doesn't allow inline asm) and see the values for the registers as you step through. I do this a lot in my unit tests to make sure the actual asm on hardware matches what I do in my emulator.
danoon
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
