Statcrew Software
Emulation of old PCs, PC hardware, or PC peripherals.
Statcrew Software
Postby thebigr311 » 2019-9-04 @ 23:27
I am having trouble installing the stat crew programs into my computer. I have Windows 10 64-bit. I have tried everything that was on the instructions, but it has not worked. The stat crew programs run only on 32-bit computers. What should I do ?
Thanks.
thebigr311
Re: Statcrew Software
Postby gdjacobs » 2019-9-05 @ 02:37
Are you wanting to run Stat Crew Legacy (i.e. the DOS version)? Do you require network support for live stats updates?
If so, you might be well served by running VDosPlus or DOS (either MS-DOS or FreeDOS) hosted in a VirtualBox VM as they're a more sure bet for emulating a packet driver or whatever you require for your application.
User avatar
gdjacobs
Return to PC Emulation
Who is online
Users browsing this forum: Google [Bot] and 1 guest
