First post, by jhhoward
Faux86 is an 8086 emulator that I have been developing to run bare metal on a Raspberry Pi. This means that the Pi does not have to boot Linux or any other OS first - it just boots straight into MS-DOS. This means a fast boot time and externally it looks like an actual x86 PC is booting.
Faux86 started as a fork of Mike Chamber's Fake86 emulator but a lot of the code has been shuffled around or rewritten.
Release binaries can be found here:
https://github.com/jhhoward/Faux86/releases
The emulator features:
- 8086 and 80186 instruction set emulation
- CGA / EGA / VGA emulation is mostly complete
- PC speaker, Adlib and Soundblaster sound emulation
- Serial mouse emulation
Currently Raspberry Pi models zero, 1, 2 and 3 are supported. To get up and running:
- Download the SD card image from the releases page
- Write the image to an SD card (e.g. using Win32DiskImager on Windows)
- Plug in your SD card to your Raspberry Pi and switch it on!
The release image has an included floppy disk boot image that the emulator will mount as drive A and boot from. The SD card will be mounted by the emulator as drive C. Just copy your favourite DOS games / apps to the SD card and you will be able to access them from the emulator.
The SD card image is fixed at 32MB as I had some problems with the emulator when trying to use larger disk sizes.
Reply 1 of 11, by digger
Cool project! And it's also interesting to find out about the existence of Circle. I had no idea a bare metal SDK existed for the Raspbery Pi family.
Although it's cool to see bare metal software being developed for the Raspberry Pi, I wonder how much actual speed gain it would offer us over a highly optimized emulator such as DOSBox running on top of a lightweight Linux distro.
Perhaps it could be potentially faster once highly optimized, but does an underlying lightweight OS such as Alpine Linux really cause that much overhead?
Just genuinely curious. I don't want to disparage the project.
Using something like Circle to develop a bare metal "booter" game for the Raspberry Pi would turn it it into something of a gaming console. 🙂
Reply 2 of 11, by jhhoward
Circle is excellent and I would definitely recommend it for embedded Raspberry Pi projects.
I'm not sure how much difference there would be in performance vs running on top of Linux but the one thing I was aiming for was a quick boot straight into the emulator (and DOS) instead of booting Linux first. The idea being that externally from a casual glance it would just look like an old x86 DOS machine right from the moment of switching it on. For increased performance you would probably get more from either hand coding ARM assembly to emulate the x86 CPU like Patrick Aalto's rpix86 emulator or writing something to dynamically recompile x86 instructions to ARM on the fly. Potentially there could also be optimisations made by using the multiple cores of the Pi 2/3/4, e.g. video emulation on a separate core.
Something that I would like to explore in the future is using the GPIO pins for additional PC peripherals. It would be fairly straightforward to hook up a PC speaker for authentic beeps but maybe serial / parallel / game ports could be hooked up to GPIO pins for old joysticks, game pads etc. Potentially null modem multiplayer with a real PC.
I've also considered writing a driver layer for SDL/SDL2 to wrap around the Circle library. It would make it easier to port other projects to a bare metal environment. e.g. DOOM, DOSBox
Reply 3 of 11, by SirNickity
That is awesome. One step closer to x86-ASIC, which is a dream project of my own. (I'm woefully incompetent to pursue that lofty goal just yet, but I'm learning.)
I would love to see a GPIO emulation of ISA. (Are there enough pins for that?)
Reply 4 of 11, by Jo22
I'd also like to see some serial port support in the future, even if it would be very barebone at first (RX/TX, GND; maybe RI, RTS/CTS too).
This would be enough for little projects, such as game play and file transfer via mull-modem or setting up a little BBS/PacketRadio system (using TNC).
SirNickity wrote on 2020-02-17, 20:57:
Me, too. GPIO currently has about 28 free i/o pins. PC/XT-Bus (8-Bit ISA) uses 62 pins. A simple form of ISA without DMA/IRQ lines might be possible, I suppose, if some of the special lines are faked.
If not, a few I/O Port-Expander chips may help to overcome the limited number of pins. Ordinary shift registers may also work, not sure.
Edit: Analog gameport support would also be nice. There's STRIG and STICK in QB 4.0, which can be lots of fun.
When I was little, I made a little alarm system by using this port, for example. Other people also connected analog sensors like NTCs/PTCs and photo diodes to the analog pins.
This allowed for building a cheap long-time oscillograph, for example.
Reply 5 of 11, by Jo22
This is slightly off-topic, but some single board computers with x86 do exist already, like 86Duino. They often use the Vortex86 processor.
Reply 7 of 11, by Flanker27S
Thanks for the recommendation, I'll make sure to give it a try. I was looking for a light and compact way to emulate old systems and programs while I'm on holidays (I was looking at these houses in Greece, and figured I'd need something small enough not to take any significant places in my luggage to keep myself busy during rainy days) and this looks like what I was looking for.
Reply 8 of 11, by digger
Jo22 wrote on 2020-02-19, 19:59:
Why reinvent the wheel here? Wouldn't it be possible to implement the Low Pin Count (LPC) bus instead? Quoting the Wikipedia article on LPC:
An integrated circuit using LPC will need 30 to 72 fewer pins than its ISA equivalent.
ISA is 16 bits wide and runs at 8MHz. LPC is 4 bits wide and runs at 33MHz, to compensate for the lower bus width.
Tiido is planning on developing an LPC-to-ISA adapter to allow ISA cards to be connected to motherboards that have a full-fledged LPC interface, support for LDRQ# signals being key.
If Faux86 could be extended to implement a complete LPC interface (providing that the Raspberry Pi has enough GPIO pins for that), then it might eventually be possible to connect physical ISA cards to it after all. 🙂
How feasible do you think this would be, jhhoward?
Reply 11 of 11, by Banjo
Just got a Raspberry Pi and have been looking all over for a way to boot straight into (emulated) DOS! This sounds amazing! Will it work on a Raspberry Pi 4 (i.e. is is just not well tested on anything above 3 or flat-out won't run)?
