First post, by hyperrmachine
I use a 32-bit computer and I have Linux Mint 19 on it.
I installed ScummVM for playing old adventure games. But when I try to launch ScummVM, it doesn't work.
I tried using Terminal to find the problem and I got this:
>scummvm
dbus[1523]: arguments to dbus_message_new_method_call() were incorrect, assertion "path != NULL" failed in file ../../../dbus/dbus-message.c line 1362.
This is normally a bug in some application using the D-Bus library.
D-Bus not built with -rdynamic so unable to print a backtrace
What does this mean? I would like a person to explain what this is.
EDIT: Also how can I fix this?
