First post, by davecom
Hi All,
Well I have my emulator to the point of booting into Casette BASIC. I just implemented the keyboard and I'm wondering why I'm only seeing apostrophes (') in BASIC when I type. The scan codes look correct to me from my PPI and I'm just storing those scan codes in port A and calling interrupt line 1 on the PIC. Has anyone seen behavior like this before and have an idea where I have gone wrong? A screenshot is attached so you can see the apostrophes I can type (no matter what key I hit). The strange u under the cursor I think is a separate problem.
Not sure why the bytes are also wrong... this is a 640K machine but maybe Casette BASIC V1 doesn't know about more than 64K?
Thanks in advance!
PS My hacky source code for the PPI is here if you're interested:
https://github.com/davecom/DK86PC/blob/master/PPI.cpp
9.17 KiB
Reply 1 of 7, by Jo22
This is very interesting, I wished I could help.
All I can say is, that GW-BASIC has a ~64KB limit, too.
According to the screenshots found online, it's 60300 bytes..
I assume it's related to the limit of what a COM file or a simple memory segment can hold in Real-Mode.
Ironically, though, GWBASIC was distributed as an EXE file..
(Makes me wonder if EXE2BIN coukd7 turn it into a COM file!)
Reply 2 of 7, by davecom
Thanks for the reply. I believe the memory issue is related to a 64K limit after learning some more.
However, the apostrophes thing I have no idea what is going on. Any ideas about the reason all keystrokes are ending up as apostrophes I would be interested in. I have verified the initial scan codes are correct, but somehow they are being transformed incorrectly I suppose.
Reply 3 of 7, by Jo22
Hi again, not sure if this helpful, but on an XT machine I sometimes got weird
characters if I used an AT keyboard switched to PC/XT mode.
More precisely, if I used the arrow keys or other extra keys not found on a true XT keyboard.
Also, the XT machine would make a beep sound whenever I pressed the extra keys (the key presses worked, though).
Again, not sure if this is related in any way. 😅
It's just the closest thing I've encountered in the past.
Reply 4 of 7, by superfury
Perhaps it's some CPU instruction calculation error? Check conditional jumps and arithmetic instructions(affected flags)?
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Older UniPCemu PC/Android/PSP releases
Reply 5 of 7, by davecom
Thanks for the replies.
So, this is an XT BIOS (the public domain one) and the scan codes are XT scan codes that I am following.
It could be a CPU bug of course—I'll need to rerun my automated tests. Related aside—is there a raw ROM that does more extensive CPU tests than the public domain BIOS does? I have alternative tests, but I don't love them. I am trying the 5150 Diagnostics ROM, but I am having some trouble booting it, so it's not super helpful at this point.
Reply 6 of 7, by superfury
Perhaps try the Landmark/Supersoft BIOS? Or perhaps strip down the test386.asm one for 8086 instructions only?
Reply 7 of 7, by davecom
So, it turned out to be a problem with my XLAT instruction. Next issue... always seeing a ü where the cursor is positioned. What controls in Casette BASIC the character under the cursor? Screenshot attached.
8.4 KiB
