First post, by mike_canada
I'm making a project for an old computer. So far I am able to make the CD boot on the computer like a floppy disk by inserting a pre-made image found at https://www.allbootdisks.com/ into the CD ISO via a Linux CD burning program, K3B.
Here's the sad part. I'm limited to using only 1.4MB off the entire 650MB CD. Why? because I haven't figured out how to make a boot image of a hard drive (instead of a floppy), and the CD-ROM drive is external and attached to the computer and no DOS CD-ROM drivers work with it. And this isn't an ordinary computer. It's a DELL thin client machine.
Now making a hard drive bootable image from scratch is tough and I'd like help doing it.
So far, I did create a 256MB image file by executing this in linux:
dd if=/dev/null of=image.img bs=1M seek=256
I can control what files are in it using linux mount. I can partition it as a FAT16 or FAT32. I even used mkdosfs (mkfs.vfat) to try to make it a DOS based file system with a 256MB disk.
I tried to see if I can do anything in DOSBOX to make the image file a bootable hard drive image for the CD, and I have no luck with the IMGMOUNT command.
I also have mtools package installed for linux but the mformat command is risky because it expects me to use a drive letter as a parameter and linux doesn't use drive letters.
Perhaps there's a unix utility I need to download and use to make the image as bootable so when I put the CD in the non-bootable computer, it will boot as if the computer is booting off from a second hard drive instead of a floppy disk.
Any ideas on how I can solve this?
Reply 1 of 6, by jmarsh
Use the 1.44MB image to load a cd driver and mscdex to access the rest of the CD through another drive letter.
Reply 2 of 6, by Cyberdyne
There is an option for a HDD emulation, but the BIOS support is more spotty for that, so yes, make a bootable floppy image, with CD drivers and MSCDEX and you can access the rest of the CD/DVD-ROM.
Bart's tools even have some utilities for finding a CD rom drive letter and then you just use %CD% in your batch files.
Reply 3 of 6, by Jo22
Rufus has HDD emulation for CD-ROMs..
Not sure if it works for or this scenario, though.
http://rufus.ie/
Reply 4 of 6, by mike_canada
Cyberdyne wrote on 2021-01-28, 08:17:
That was the method I tried to use with quite a few generic CD-ROM drivers but none would load properly in config.sys and unless I can get one running in config.sys, MSCDEX will be of no use.
The CD/DVD drive in question is an external USB one.
Reply 5 of 6, by superfury
Afaik MS-DOS USB CD-ROM drivers don't exist? Normal CD-ROM drivers(ATAPI on the motherboard without USB) have lots of drivers though(OAKCDROM, VIDE-CDD etc.).
For that matter, afaik USB and everything connected to it is completely unsupported in MS-DOS anyways.
The only alternative of ATA/ATAPI CD-ROM drivers I know of is that there exist some CD-ROM drivers that use the serial or parallel port I think (don't remember which of those two it was for)?
The BIOS might have support for CD-ROM containing a bootable hard disk image. You'll have to properly configure the ISO creating tool for that, though. It's just replacing the floppy disk image with a hard disk image that's bootable, combined with the configuration of a hard disk boot instead of a floppy disk boot. Thus using an El Torito HDD boot from CD-ROM instead of an El Torito floppy boot.
UniPCemu Git repository
Reply 6 of 6, by chinny22
You can get a bit more then 1.44mb easy enough by having the boot disk create a ram disk just like the generic Win98 boot disk does.
Don't know if that'll help just throwing out ideas
