Athlon XP 1800+ or Sempron 2800?
First post, by eL_PuSHeR
Well, I currently have an Athlon XP 1800+ plugged in my VIA KT333 mainboard. I'd like to upgrade (2800Mhz is the maximum for a 333Mhz bus, right?) I am browsing shops and I only see Sempron processors. How do they perform? I visited www.amd.com and it seems the Sempron has a 256KB L2 cache versus the 512KB one on the Athlon XP. Would I benefit from getting a Sempron 2800? or should I look for a real Athlon XP 2800+?
Well, Found both:
Sempron 2800 costs 95€ plus VAT
Athlon XP 2800 costs 132 € plus VAT
I think I am going to purchase the Atlon XP 2800 soon.
Reply 4 of 26, by Freddo
eL_PuSHeR wrote:
Exactly. That's 1GHz (approx) more than what I currently have. 😎
Not really. More like the half of 1GHz. The AMD 1800+ XP runs at 1533MHz and the AMD 2800+ XP Barton runs at 2083Ghz.
Reply 6 of 26, by Freddo
eL_PuSHeR wrote:
I think you are wrong. My Athlon XP 1800+ is running at 1152,61MHz (real).
Then you must be running the FSB at 100 instead of the intended 133. Change it in the BIOS.
Reply 7 of 26, by eL_PuSHeR
How can I check it? It is safe to change it in bios?
PS - I think you are right....
Edit3: I fixed it in BIOS. Yay! Everything seems to be working properly. Thank you for pointing it out to me. I would have never noticed. 😎
Reply 9 of 26, by DosFreak
My XP 2800 is 167.05X13.5=2215.12.
Have had it since Sept 2002. Very good investment. Always thought about buying a newer processor but there's really not much point. The XP 2800 is still very powerful and enough to run even the latest games, unless of course your an FPS nut who requires the highest FPS you can get.
That's an old ver of WCPUID by the wat.
Make your games work offline
Reply 10 of 26, by Targaff
Hrm, I've been running a Duron 1.6 and considering getting an XP 2800 as well (266 fsb, though, which seem to be a real pain to get hold of). It's $22 between that and an XP 2600, though ($94 and $116 respectively) - reckon it's worth spending that extra cash?
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Reply 12 of 26, by Targaff
It only supports 266, but I can get 2600 or 2800 at that.
Reply 13 of 26, by Snover
Ah, sorry, I see what you're saying now. For $22, you might as well get the extra boost. I think that the largish price differential may be due to use of a different core in the 2800 versus the 2600. It may also be very limited price gouging of the resellers knowing that you're gonna want the most power you can get on that FSB 😉
Yes, it’s my fault.
Reply 15 of 26, by Targaff
My mobo doesn't handle Barton, so that's something i have to be aware of when buying, I guess (it's an Asrock K7VT2, which supports "Thorton, Thoroughbred A/B and Palomino", so they say). I was quite surprised to find that there even was a 266 non-Barton processor that high, but apparently so...
Snover: your comment about price-gouging is one of the reasons I'm wary. It may be "just" $22, but it still seems a lot to me for a jump from 2133MHz to ~2250.
Thanks for the info.
Reply 16 of 26, by swaaye
Whatever core the Sempron uses is newer than the Barton.
I have had a Barton in both a KT266A and KT333-based boards. It will come up as unknown CPU but it will work fine. You just need to be able to set bus speed and multiplier in the BIOS or you'll be stuck at like 100FSB/6x = 600Mhz.
Best thing to do would be to get a mobile barton 2200+ for cheap and overclock the hell out of it. Mine is doing 2.2Ghz at a mere 1.6v!
If you want cheap, just make sure it's not a Duron and you'll be good to go. The extra cache on Barton doesn't make much difference at all honestly. You can read reviews if you like on that. It's not a big deal.
Reply 17 of 26, by DosFreak
If your getting a new processor (and intend to use DosBox) I'd definetly get one with more L2 cache. Currently only have 256k so when I upgrade to a newer processor I'll definetly be going for at least a 1mb L2.
Reply 18 of 26, by swaaye
http://www.aceshardware.com/read.jsp?id=50000364
Another good example of L2 being less than defining of processor speed is that a Athlon 64 939 with 512k cache will beat my Athlon 64 754 with 1MB cache. The dual channel memory of the 939 chip more than makes up for the L2 cache size drop.
Pentium 4 is an example of a CPU that gets a lot of benefit from L2 cache size. Athlon XP and Athlon 64 don't get too much from it. Pentium M is also a good example of L2 helping a lot, but Intel's L2 cache's are absolute monsters in speed compared to AMD's and that's part of it. And that 2MB cache on Pentium M (Dothan) is pretty crazy huge.
Reply 19 of 26, by Targaff
"You see, we've already got one!"
Not sure what your issue is with them, to be honest, they're a bit long in the tooth now, but if you want cheap - and I mean cheap - they're still not that bad. Mine deals handily with most of the stuff I've thrown at it, anyway; but then, I'm not running the latest greatest.
That's why I'm on VOGONS, see :]
