First post, by superfury
Anyone can tell me how the ET4000/W32 pattern and source map wrapping work? How are they applied? What happens when an operation is started with the X/Y coordinates out of range?
How does saving and restoring state work with regards to pattern and source maps when out of range (not within range of the wrapping specified for horizontal or vertical wrapping)? Or do they start from 0,0 for all operations started or restored no matter what's programmed into the X/Y coordinates at registers ?
Anyone? Can't find much documentation on this, other than some weird algorithmic logic applied in PCem (which I don't fully understand, since it seems to have some weird borders(wrapping too much seemingly, with weird horizontal multipliers and dividers that don't make immediate sense?) etc. that are applied looking at the formulas)?
This is what I've gotten so far(when starting a graphics operation through byte 3 of the destination address or through the operation command register bit 4):
void Tseng4k_startAccelerator()
int_64 horizontalwrappings,horizontalsize;
//Start the accelerator's function.
//Load all internal precalcs required and initialize all local required CPU-readonly variables.
Tseng4k_decodeAcceleratorRegisters(); //Load all registers into the accelerator's precalcs!
//TODO: Load the read-only variables for the accelerator to start using. Also depends on the reloadPatternAddress and reloadSourceAddress ACL settings.
if (et34k(getActiveVGA())->W32_ACLregs.reloadPatternAddress == 0) //To reload the pattern address?
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress = et34k(getActiveVGA())->W32_ACLregs.patternmapaddress; //Pattern address reload!
if (et34k(getActiveVGA())->W32_ACLregs.reloadSourceAddress == 0) //To reload the pattern address?
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress = et34k(getActiveVGA())->W32_ACLregs.sourcemapaddress; //Pattern address reload!
//Perform what wrapping?
et34k(getActiveVGA())->W32_ACLregs.patternwrap_x = Tseng4k_wrap_x[et34k(getActiveVGA())->W32_ACLregs.Xpatternwrap]; //What horizontal wrapping to use!
et34k(getActiveVGA())->W32_ACLregs.patternwrap_y = Tseng4k_wrap_x[et34k(getActiveVGA())->W32_ACLregs.Ypatternwrap]; //What horizontal wrapping to use!
et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x = Tseng4k_wrap_x[et34k(getActiveVGA())->W32_ACLregs.Xsourcewrap]; //What horizontal wrapping to use!
et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y = Tseng4k_wrap_x[et34k(getActiveVGA())->W32_ACLregs.Ysourcewrap]; //What horizontal wrapping to use!
//Perform wrapping of the inputs!
//First, wrap pattern!
et34k(getActiveVGA())->W32_ACLregs.patternmap_x = et34k(getActiveVGA())->W32_ACLregs.Xposition; //Don't wrap our idea of X!
et34k(getActiveVGA())->W32_ACLregs.patternmap_y = et34k(getActiveVGA())->W32_ACLregs.Yposition; //Don't wrap our idea of Y!
horizontalwrappings = 0; //Default: nothing is horizontally wrapped!
horizontalsize = (et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1); //How large is the horizontal row?
if (et34k(getActiveVGA())->W32_ACLregs.patternwrap_x!=(uint_32)~0) //X wrapping?
horizontalwrappings = (int_64)(et34k(getActiveVGA())->W32_ACLregs.Xposition / (et34k(getActiveVGA())->W32_ACLregs.patternwrap_x + 1)); //How many times is X wrapped?
et34k(getActiveVGA())->W32_ACLregs.patternmap_x = et34k(getActiveVGA())->W32_ACLregs.Xposition & et34k(getActiveVGA())->W32_ACLregs.patternwrap_x; //Wrap our idea of X!
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress -= horizontalwrappings * (et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1); //How many times is X wrapped, adding to Y at the address level?
if (et34k(getActiveVGA())->W32_ACLregs.patternwrap_y!=(uint_32)~0) //Y wrapping?
horizontalwrappings -= (int_64)((et34k(getActiveVGA())->W32_ACLregs.patternmap_y / (et34k(getActiveVGA())->W32_ACLregs.patternwrap_y + 1)) * (et34k(getActiveVGA())->W32_ACLregs.patternwrap_y + 1)); //How much is wrapped in the Y coordinate!
et34k(getActiveVGA())->W32_ACLregs.patternmap_y = et34k(getActiveVGA())->W32_ACLregs.patternmap_y & et34k(getActiveVGA())->W32_ACLregs.patternwrap_y; //Wrap to our idea of Y!
else
horizontalwrappings = 0; //Nothing to wrap!
//Next, wrap source!
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x = et34k(getActiveVGA())->W32_ACLregs.Xposition; //Don't wrap our idea of X!
et34k(getActiveVGA())->W32_ACLregs.sourcemap_y = et34k(getActiveVGA())->W32_ACLregs.Yposition; //Don't wrap our idea of Y!
horizontalsize = (et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1); //How large is the horizontal row?
if (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x != (uint_32)~0) //X wrapping?
horizontalwrappings = (int_64)(et34k(getActiveVGA())->W32_ACLregs.Xposition / (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x + 1)); //How many times is X wrapped?
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x = et34k(getActiveVGA())->W32_ACLregs.Xposition & et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x; //Wrap our idea of X!
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress -= horizontalwrappings * (et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1); //How many times is X wrapped, adding to Y at the address level?
if (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y != (uint_32)~0) //Y wrapping?
horizontalwrappings -= (int_64)((et34k(getActiveVGA())->W32_ACLregs.sourcemap_y / (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y + 1)) * (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y + 1)); //How much is wrapped in the Y coordinate!
et34k(getActiveVGA())->W32_ACLregs.sourcemap_y = et34k(getActiveVGA())->W32_ACLregs.sourcemap_y & et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y; //Wrap to our idea of Y!
else
//Backup the original values before starting!
et34k(getActiveVGA())->W32_ACLregs.patternmap_x_backup = et34k(getActiveVGA())->W32_ACLregs.patternmap_x; //Backup!
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x_backup = et34k(getActiveVGA())->W32_ACLregs.sourcemap_x; //Backup!
et34k(getActiveVGA())->W32_ACLregs.patternmapaddress_backup = et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress; //Backup!
et34k(getActiveVGA())->W32_ACLregs.sourcemapaddress_backup = et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress; //Backup!
et34k(getActiveVGA())->W32_ACLregs.destinationaddress_backup = et34k(getActiveVGA())->W32_ACLregs.destinationaddress; //Backup!
if ((et34k(getActiveVGA())->W32_MMUregisters[1][0x9C] & 7) == 0) //No CPU version?
et34k(getActiveVGA())->W32_acceleratorleft = 1; //Always more left until finishing! This keeps us running!
For reference, the registers are loaded like this:
void Tseng4k_decodeAcceleratorRegisters()
//TODO: Load and decode all accelerator registers into easy to use variables in the accelerator
et34k(getActiveVGA())->W32_ACLregs.patternmapaddress = (getTsengLE24(&et34k(getActiveVGA())->W32_MMUregisters[1][0x80]) & 0x3FFFFF); //Pattern map address
et34k(getActiveVGA())->W32_ACLregs.sourcemapaddress = (getTsengLE24(&et34k(getActiveVGA())->W32_MMUregisters[1][0x84]) & 0x3FFFFF); //Source map address
et34k(getActiveVGA())->W32_ACLregs.patternYoffset = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x88]) & 0xFFF); //Pattern Y offset
et34k(getActiveVGA())->W32_ACLregs.sourceYoffset = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x8A]) & 0xFFF); //Source Y offset
et34k(getActiveVGA())->W32_ACLregs.destinationYoffset = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x8C]) & 0xFFF); //Destination Y offset
et34k(getActiveVGA())->W32_ACLregs.virtualbussize = (et34k(getActiveVGA())->W32_MMUregisters[1][0x8E]&3); //Virtual bus size, powers of 2! 0=1, 1=2, 2=4, 3=Reserved
et34k(getActiveVGA())->W32_ACLregs.XYdirection = (et34k(getActiveVGA())->W32_MMUregisters[1][0x8F] & 3); //0=+1,+1; 1=-1,+1; 2=+1,-1; 3=-1,-1. Essentially bit 0=X direction, bit 1=Y direction. Set=Decreasing, Cleared=Increasing
et34k(getActiveVGA())->W32_ACLregs.Xpatternwrap = (et34k(getActiveVGA())->W32_MMUregisters[1][0x90] & 7); //Power of 2. more than 64 or less than 4 is none.
et34k(getActiveVGA())->W32_ACLregs.Ypatternwrap = ((et34k(getActiveVGA())->W32_MMUregisters[1][0x90] >> 4) & 7); //Power of 2. more than 8 is none.
et34k(getActiveVGA())->W32_ACLregs.Xsourcewrap = (et34k(getActiveVGA())->W32_MMUregisters[1][0x92] & 7); //See pattern wrap
et34k(getActiveVGA())->W32_ACLregs.Ysourcewrap = ((et34k(getActiveVGA())->W32_MMUregisters[1][0x92] >> 4) & 7); //See pattern wrap
et34k(getActiveVGA())->W32_ACLregs.Xposition = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x94]) & 0xFFF); //X position
et34k(getActiveVGA())->W32_ACLregs.Yposition = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x96]) & 0xFFF); //Y position
et34k(getActiveVGA())->W32_ACLregs.Xcount = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x98]) & 0xFFF); //X count
et34k(getActiveVGA())->W32_ACLregs.Ycount = (getTsengLE16(&et34k(getActiveVGA())->W32_MMUregisters[1][0x9A]) & 0xFFF); //Y count
et34k(getActiveVGA())->W32_ACLregs.reloadPatternAddress = GETBITS(et34k(getActiveVGA())->W32_MMUregisters[1][0x9D],1,1); //Reload of pattern address. When 1, use the internal pattern address register.
et34k(getActiveVGA())->W32_ACLregs.reloadSourceAddress = GETBITS(et34k(getActiveVGA())->W32_MMUregisters[1][0x9D],0,1); //Reload of source address. When 1, use the internal source address register.
et34k(getActiveVGA())->W32_ACLregs.BGFG_RasterOperation[0] = et34k(getActiveVGA())->W32_MMUregisters[1][0x9E]; //Index 0=BG, 1=FG
et34k(getActiveVGA())->W32_ACLregs.BGFG_RasterOperation[1] = et34k(getActiveVGA())->W32_MMUregisters[1][0x9F]; //Index 0=BG, 1=FG
et34k(getActiveVGA())->W32_ACLregs.destinationaddress = (getTsengLE24(&et34k(getActiveVGA())->W32_MMUregisters[1][0xA0]) & 0x3FFFFF); //Destination address
And applied during runtime (when blitting) like this:
byte et4k_stepy()
++et34k(getActiveVGA())->W32_ACLregs.Yposition;
et34k(getActiveVGA())->W32_ACLregs.destinationaddress = et34k(getActiveVGA())->W32_ACLregs.destinationaddress_backup; //Make sure that we're jumping from the original!
if (et34k(getActiveVGA())->W32_ACLregs.XYdirection&2) //Negative Y?
et34k(getActiveVGA())->W32_ACLregs.destinationaddress -= et34k(getActiveVGA())->W32_ACLregs.destinationYoffset + 1; //Next address!
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress -= et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1; //Next address!
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress -= et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1; //Next address!
--et34k(getActiveVGA())->W32_ACLregs.patternmap_y;
if (et34k(getActiveVGA())->W32_ACLregs.patternmap_y == ((uint_32)~0)) //Overflow?
if (et34k(getActiveVGA())->W32_ACLregs.patternwrap_y != (uint_32)~0) //Wrapping Y?
et34k(getActiveVGA())->W32_ACLregs.patternmap_y = et34k(getActiveVGA())->W32_ACLregs.patternwrap_y; //Returning to the bottom!
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress += ((et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1) * (((uint_64)et34k(getActiveVGA())->W32_ACLregs.patternwrap_y) + 1)); //Apply Y address wrap!
--et34k(getActiveVGA())->W32_ACLregs.sourcemap_y;
if (et34k(getActiveVGA())->W32_ACLregs.sourcemap_y == ((uint_32)~0)) //Overflow?
if (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y != (uint_32)~0) //Wrapping Y?
et34k(getActiveVGA())->W32_ACLregs.sourcemap_y = et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y; //Returning to the bottom!
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress += ((et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1) * (((uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y) + 1)); //Apply Y address wrap!
else //Positive Y?
et34k(getActiveVGA())->W32_ACLregs.destinationaddress += et34k(getActiveVGA())->W32_ACLregs.destinationYoffset + 1; //Next address!
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress += et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1; //Next address!
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress += et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1; //Next address!
++et34k(getActiveVGA())->W32_ACLregs.patternmap_y;
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.patternmap_y > (uint_64)et34k(getActiveVGA())->W32_ACLregs.patternwrap_y) //Wrapping point reached?
et34k(getActiveVGA())->W32_ACLregs.patternmap_y = 0; //Reset!
et34k(getActiveVGA())->W32_ACLregs.internalpatternaddress -= (et34k(getActiveVGA())->W32_ACLregs.patternYoffset + 1) * (et34k(getActiveVGA())->W32_ACLregs.patternwrap_y + 1); //Go back to the backup address!
++et34k(getActiveVGA())->W32_ACLregs.sourcemap_y;
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcemap_y > (uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y) //Wrapping point reached?
et34k(getActiveVGA())->W32_ACLregs.sourcemap_y = 0; //Reset!
et34k(getActiveVGA())->W32_ACLregs.internalsourceaddress -= (et34k(getActiveVGA())->W32_ACLregs.sourceYoffset + 1) * (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_y + 1); //Go back to the backup address!
et34k(getActiveVGA())->W32_ACLregs.destinationaddress_backup = et34k(getActiveVGA())->W32_ACLregs.destinationaddress; //Save the new line on the destination address to jump back to!
if (et34k(getActiveVGA())->W32_ACLregs.Yposition>et34k(getActiveVGA())->W32_ACLregs.Ycount)
//Leave Y position and addresses alone!
return 2; //Y count reached!
return 0; //No overflow!
byte et4k_stepx()
byte result;
++et34k(getActiveVGA())->W32_ACLregs.Xposition;
if (et34k(getActiveVGA())->W32_ACLregs.XYdirection&1) //Negative X?
--et34k(getActiveVGA())->W32_ACLregs.destinationaddress; //Next address!
--et34k(getActiveVGA())->W32_ACLregs.patternmap_x; //Next address!
--et34k(getActiveVGA())->W32_ACLregs.sourcemap_x; //Next address!
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.patternmap_x == ((uint_32)~0)) //X overflow according to wrapping?
et34k(getActiveVGA())->W32_ACLregs.patternmap_x += (uint_32)(et34k(getActiveVGA())->W32_ACLregs.patternwrap_x + 1); //Wrap it!
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcemap_x == ((uint_32)~0)) //X overflow according to wrapping?
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x += (uint_32)(et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x + 1); //Wrap it!
else //Positive X?
++et34k(getActiveVGA())->W32_ACLregs.destinationaddress; //Next address!
++et34k(getActiveVGA())->W32_ACLregs.patternmap_x; //Next address!
++et34k(getActiveVGA())->W32_ACLregs.sourcemap_x; //Next address!
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.patternmap_x > (uint_64)et34k(getActiveVGA())->W32_ACLregs.patternwrap_x) //X overflow according to wrapping?
et34k(getActiveVGA())->W32_ACLregs.patternmap_x -= (et34k(getActiveVGA())->W32_ACLregs.patternwrap_x+1); //Wrap it!
if ((uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcemap_x > (uint_64)et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x) //X overflow according to wrapping?
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x -= (et34k(getActiveVGA())->W32_ACLregs.sourcewrap_x+1); //Wrap it!
if (et34k(getActiveVGA())->W32_ACLregs.Xposition>et34k(getActiveVGA())->W32_ACLregs.Xcount)
//X overflow? Step vertically!
et34k(getActiveVGA())->W32_ACLregs.Xposition = 0; //Reset
et34k(getActiveVGA())->W32_ACLregs.patternmap_x = et34k(getActiveVGA())->W32_ACLregs.patternmap_x_backup; //Restore the backup!
et34k(getActiveVGA())->W32_ACLregs.sourcemap_x = et34k(getActiveVGA())->W32_ACLregs.sourcemap_x_backup; //Restore the backup!
result = 1 | (et4k_stepy()); //Step Y! X count reached!
return result; //Give the result!
Anyone?
UniPCemu Git repository
