First post, by badflame
I tried 3D Analyze to fix "The Lord of the Rings: The Fellowship of the Ring" on Windows 10. This tool patch the game and works well, but when I use the BAT file that 3D Analyze makes automatically (clicking "Save batch file!" button) to play the game without the need to manually open the program and click "SELECT" and "RUN", appears this error message: "Could not copy forceDLL.dll".
Of course I'm running Windows as administrator, but also tried to activate the option "run as administrator" in "3danalyzer.exe" properties.
Can someone using 3D Analyze help me?
Thanks.
UPDATE
Ok, I have figured out the solution. You need to modify the BAT file using short path names for the game directory. Otherwise 3D Analyze is unable to find the path.
I hope my experience serves other users.
