DosBox
First post, by Xorcist
DosBox is a great DOS emulator. It's only at version .40, but it's coming along well and supports a good deal of emulated audio and video hardware (and runs both under Windows as well as Linux). It even has joystick support! I was able to get some of my old time favorites up and running under DosBox with little to no trouble (ones that I had a tough time getting to run under Windows 98 and 2000). Check it out, it's worth the look, trust me.
Reply 1 of 20, by Snover
I love the idea that DOSBox has, but it hasn't worked nearly as successfully for me. I think this should improve a LOT when they implement protected mode and finish 386 instructions. (I know I can't wait!)
What games DO run well in DOSBox? (ie. What games did you play on it? --I'd like to try them.)
Yes, it’s my fault.
Reply 2 of 20, by Nicht Sehr Gut
Start with the most ancient you can find and work your way forward.
Early 386 games seem to be the upper limit. Most old Sierra titles are a no-go, but the age-old Disney/Westwood titles work quite well (Mickey's 123's/ABC's, etc...).
DosBox is (so far) the only way I've seen to run those titles on new machines (they die instantly on new machines due to processor speed).
Reply 3 of 20, by Snover
Yeah...I dunno... I've found games that old aren't games I really want to play. Probably just because I'm not really old, so I don't remember games before, like, 1990.
Yes, it’s my fault.
Reply 4 of 20, by Nicht Sehr Gut
Actually, about the only ones I'll touch from that era are "special interest" items, which usually translates to: good game not available on any other format.
"WASTELAND" is in a kind of "grey area". It's one of the "all-time greatest RPG's". Was available on the PC and C64 only. Kind of a toss-up as to which would be better to play. The C64 has sound (PC is speaker only), but the PC has a slight edge on graphics.
"Bandit Kings of Ancient China" would be better played on an Amiga emulator. (PC was CGA & Speaker only)
"Sword of the Samurai" (Microprose) is best on the PC because it was PC only.
A lot of PC games from the late 80's and early 90's were ports from other systems and quite frequently were inferior. So, checking for versions on "alternate systems" is a good thing.
Whatever works best, I say...
Reply 5 of 20, by Snover
WASTELAND... A game that's that old ... on a PC that old ... having an edge on graphics? I mean, call me nuts, but wouldn't the graphics most likely have been EGA or CGA?
Yes, it’s my fault.
Reply 6 of 20, by Nicht Sehr Gut
Administrator wrote:
WASTELAND... A game that's that old ... on a PC that old ... having an edge on graphics? I mean, call me nuts, ...
Ok. You are nuts.
Correct, WASTELAND is EGA, 16 colors from a palette of 64 (with some poorly chosen colors in there). The Commodore 64 had 16 colors from a palette of 16 (only 16, but better selection).
So both had a palette of 16 colors with a screen resolution of 320x200. However, the way the C64 displayed 16 colors was _not_ a straight-forward method. This meant you had a color limitation (if I remember correctly) of no more than 3 colors within a nine-pixel grid (or something very close to that). I discovered this when using a Koala Pad (a graphics tablet) with a C64.
Whenever I tried to introduce a new color beyond the specs, it would change other pixel colors around the area that I was drawing. The end result was that you couldn't simply take a 320x200x16 color image from another computer and convert it to C64 format. You would have spurious color pixels sprayed all over the screen. Every image converted to the C64 had to be "massaged", arranging different color pixels so that they wouldn't violate the color limitations.
So if you look at WASTELAND on both, I think you'll find that while the PC version had a few poor color choices, the overall image quality was better.
Reply 7 of 20, by Snover
Ok. You are nuts.
Yeah, probably, but you don't have to go around flaunting it! *sniff* 😉
This meant you had a color limitation (if I remember correctly) of no more than 3 colors within a nine-pixel grid (or something very close to that)...The end result was that you couldn't simply take a 320x200x16 color image from another computer and convert it to C64 format. You would have spurious color pixels sprayed all over the screen.
That is, beyond a doubt, the most fucked up thing I've ever heard. Any articles or information on WHY the C64 developers did that?
Yes, it’s my fault.
Reply 8 of 20, by Harekiet
Rank DOSBox Author
DOSBox Author
Well it's pretty simple if you look at how the VIC chip of the c64 generates the screen 😀 Since the graphics mode is basically a bit freaked up standard character mode with 8x8 pixel characters, with all characters spread out evenly through video memory. But still with the color functionality of the original character mode.
As far as i know 320x200 has 2 colors per 8x8 pixel block and you can also switch to 160x200 so you have 4 colors per 8x8 block.
Ah well better stick to 16 color ega mode with 64 colors. Although a lot of games only use the first 16 and don't use the full range. Not many good colors you can make with 2 shades of red/blue/green anyway 😜 Better use 16 color vga modes so you can use the vga palette, great example of this in the crystal dreams demo 😀
Reply 9 of 20, by Nicht Sehr Gut
Hey, you asked...*shrug*
That is, beyond a doubt, the most exuberate thing I've ever heard.
Actually, there's plenty more where that came from...
I think it would fall under the category of "It's 1981 and we have limited technology and a limited budget". There were many other weird things with the classics. You usually didn't find out about them until well after you invested a lot of cash.
The Atari 8-bit computers (400/600/800/1200/1300 XE/XL,etc...) had a palette of 256 colors. You could have all 256 on-screen at once, but only _4 colors_ were allowed per scanline.
Colecovision game consoles had 32 sprites. You could have all 32 onscreen, but only 4 were allowed to be on the same horizontal position (Otherwise, you got flickering, sometimes _blinking_ sprites).
But the C64 was the "King of Bizarre Things". From the power supplies that were filled with goo (which had the double-impact of making them overheat _way_ too much and also made them impossible to repair) to the way Commodore would contract out some of the C64 manufacturing to the lowest bidder.
I think the ultimate was this:
Customer: I'm trying to type on my word processor, but my keyboard's not working right. I'm getting garbage characters and other characters are missing.
Me: Do you have a joystick connected to port 1 sir?
Customer: Well, yes. But what's that got to do with...
Me: Remove it sir.
Customer: You're kidding.
Me: Nope.
Customer: (slight delay) What the...!? That did it!
That's why port 2 was almost always used for 1-player stick games and not port 1. You can actually connect a stick to port 1, move it around and watch it type garbage characters across the screen.
Reply 10 of 20, by Nicht Sehr Gut
You know, I was thinking that it was 8x8 but somehow it didn't seem right. That makes it all the more amazing that they could do what they did. Arbitrary color limitations like that could drive an artist nuts.
All depends. That "speaker" audio alone could push me toward a C64 version. And if there was an Amiga version, I don't think I'll even consider the PC version.
Reply 11 of 20, by Snover
Nice job of, err, neutering my profanity. :p
Wow, this reminds me of programming games in ASCII (like Megazeux and ZZT). If you can have four colours in an 8x8 block, but with half horizontal resolution, what's the benefit? Sounds like it just renders with 2 colours per 8x8 at 320x200, then downsizes to 160x200, rather than making any changes at all to display mode other than horizontal resolution.
The Atari 8-bit computers (400/600/800/1200/1300 XE/XL,etc...) had a palette of 256 colors. You could have all 256 on-screen at once, but only 4 colors were allowed per scanline.
Weird hardware. What caused THIS limitation? And, in any case, 2 colours per 8x8 block is still much worse, hands-down, IMO.
Ah, I love it!! 😁
I think the ultimate was this: Customer: I'm trying to type on my word processor, but my keyboard's not working right. I'm getti […]
Me: Remove it sir.
Me: Nope.
I take it you worked for Commodore, then? What other juicy tidbits have you? (I just loooove juicy bits. [IMG=images/smilies/rolleyes.gif]Sly[/IMG])
Ah, the Amiga. Now THERE'S a breakfast--err, I mean, COMPUTER of champions. Or, at least, it was...(never actually owned one, never could really figure out how to use Workbench, but hey. Still a great machine. Maybe I should buy this...or maybe not, since I'm broke.)
In any case, I know I can't stand PC speaker sound (especially since it comes through the PC speaker and not my sound card, making it virtually impossible to hear over my 4(!) case fans) and that if any game offers ANY alternative, I'll jump at the chance, even if it is with some exceptionally bad graphics.
<reminiscing>(I remember that there were two C64s that my third-grade teacher owned and had in the classroom for us to play on during breaks. Ah, those were the days. Used to play this maze game that took about 5 minutes to load that reminded me of the maze game on the old Prodigy service. Ah, to be six again.)</reminiscing>
Toodles.
Yes, it’s my fault.
Reply 12 of 20, by Nicht Sehr Gut
*gack* ungh...having flashbacks...basic...arrays...flowcharting...COBOL
NO! NO COBOL! COBOL BAD! GO AWAY!
*ERROR. FAIL-SAFE EXECUTED. COBOL MEMORY REPRESSED AND RELOCATED AT BOTTOM OF BASE MEMORY*
there...feel better now...headache easing...
I think this was one of the main problems for the Atari hardware. No idea why there was a 4-color-per-scanline limitation, but it made multi-color images on the Atari's a massive pain. The scanline limitation wasn't that big a deal for still images (like in an adventure), but it made moving objects a major pain.
Also, the commodore multi-color "sprites" had advantages over the single-color Atari "player/missle graphics".
Only for a short time as a rep, I spent more time as a general "computer salesman". Allowed me tinker with a lot of the old hardware that I couldn't actually afford to buy (SX-64, really early PC-clones, Apple IIc's, Atari ST, etc...).
No real "insider" info here, most of these things were commonly known by C64 owners back then. The contracting issue is why there were minor variations of the C64 even though the actual design had not changed. Commodore was trying to make the C64 as cheap as possible and they succeeded. One side-effect of this was that the number of defective C64's skyrocketed. I still remember the stack of dead C64's that reached to the ceiling in our store. Helped sell a few "protection" programs.
Indeed, a fine lass she was...*sigh*
Like other greats, it was never treated properly. American programmers usually treated it like a "weird PC", 16-color displays...ignoring the 4096 color palette, the stereo audio, the speech synthesizer,etc...
(IE: King's Quest I)
The Europeans treated it like a game console. Trashing the OS and directly hitting the hardware, which meant boatloads of compatibility issues. A lot of times they even treated it as an Atari-ST emulator (IE:AD&D Dragons of Flame, was coded on the ST then ported to the Amiga. The ST version could be installed to a hard drive because it was OS-compatible code. The port was "dumped" onto the Amiga with only the minimal changes needed to make it work. Since the Amiga had basically all the basic hardware that the ST had, no attempt was made to make it OS-friendly. They just made minor changes to make it "hit the hardware" on the Amiga.)
The combined effect was that few titles really show what the Amiga was capable of...they usually scaled things back so a port would be easier to make.
There were exceptions. The Amiga version of "Conquest of Camelot" played the Roland music from the PC version, for example. BTW, ignore most of the early PC Sierra titles and play the Amiga versions. It fixes speed issues, better palette for some games, etc...)
Workbench didn't always have the most logical setup ("Initialize" vs
"Format Disk") but it was still a dream compared to Windows v1 & 2 and to an extent v3.
Maybe I should buy this[/url]...or maybe not, since I'm broke.)
Already gone by the time I saw it.
For basic blips and beeps, it works. Nothing beyond that. I'm amazed at some of the things programmers were able to make it do, but even an Atari 2600 beats it handily.
Sometimes it's a trade-off.
WinUAE is quite useable as an emulator and plays most all the classics. Someday, I'll figure how to make it run my "Defender of the Crown II" CD.
Reply 13 of 20, by Harekiet
Rank DOSBox Author
DOSBox Author
I think this was one of the main problems for the Atari hardware. No idea why there was a 4-color- per-scanline limitation, but it made multi-color images on the Atari's a massive pain. The scanline limitation wasn't that big a deal for still images (like in an adventure), but it made moving objects a major pain.
Yeah i'd rather have the c64 hardware if you can at least have multicolor sprites and 4 colors per scan line is horrible. Probably has to do with the hardware loading 4 colors into some registers at the beginning of each scanline and use that for bitdata. Requires some tricky programming to change it for each line too i think 😀
Ah well there have been some games that used "realsound" to actually make pretty nice sound. You could use the pc-speaker as wave sound-output device. Still have to get that correctly emulated though, since the games setup an insanely high timer interval. Too bad there are so few games that used the tandy 3-sound that actually doesn't so that bad.
Reply 14 of 20, by Snover
Yeah, RealSound was pretty good, but it was a bad hardware hack that wreaks havoc on anything other than pure-DOS mode. (And it was in mono, which meant it was still worse than the Amiga.)
And UGH! You'd think that AdLib's manufacturers would have gone with sampled modules like the Amiga, but noooo...crappy synthesized crap. *grumble*
Yes, it’s my fault.
Reply 15 of 20, by DosFreak
Realsound support would be AWESOME. I want my Mean Streets to work!
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 18 of 20, by Nicht Sehr Gut
Snover wrote:
Well, yeah, I mean, it's pretty rocking when it works, but it's still a cheap hack.
You're talking to the guy who's still looking for a way to run "Mickey's ABC's" with the "Disney SoundSource" in emulation. ;p
