First post, by Snover
Please please PLEASE correct any errors you see in this document, moderators, or post any errors to be corrected, users. Creative Labs' documentation varies a lot, so some values are interpolated, and others, well, I think are bullshit (such as a 50kHz frequency response on the AWE32). Thanks!
Oh yeah -- please also post what the release years for these cards are.
<hr>
Sound Blaster
&&WAVE:
&&&&SAMPLE RATE: 4kHz - 15kHz (recording), 4kHz - 24kHz (playback)
&&&&RESOLUTION: 8-bit
&&&&CHANNELS: monaural
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: fm
&&&&POLYPHONY: 11 (monaural) + 12 stereo CMS? (1.0 only)
&&&&ROM: none
&&&&RAM: none
&&SNR: 48dB
&&FREQUENCY RESPONSE: 100Hz - 10kHz
&&CD AUDIO: none
Sound Blaster 2.0
&&WAVE:
&&&&SAMPLE RATE: 4kHz - 44kHz
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: fm
&&&&ROM: none
&&&&RAM: none
&&SNR: 48dB
&&CD AUDIO: yes (propietary?)
Sound Blaster Pro
&&WAVE:
&&&&SAMPLE RATE: 4kHz - 44.1kHz (mono), 5kHz - 22.1kHz (stereo)
&&&&CHANNELS: stereo
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: fm
&&&&POLYPHONY: 11 (stereo)
&&&&ROM: none
&&&&RAM: none
&&SNR: 48dB
&&CD AUDIO: analogue (propietary?)
Sound Blaster Pro 2.0
&&WAVE:
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: opl3
&&&&ROM: none
&&&&RAM: none
&&SNR: 48dB
Sound Blaster 16
&&WAVE:
&&&&SAMPLE RATE: 5kHz - 44.1kHz
&&&&RESOLUTION: 16-bit
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: opl3
&&&&POLYPHONY: ?
&&&&ROM: none
&&&&RAM: none
&&SNR: 85dB?
&&FREQUENCY RESPONSE: 30Hz - 20kHz
Sound Blaster 16 Wave Effects
&&WAVE:
&&&&3D AUDIO: 3d stereo
&&MIDI:
&&&&TYPE: software wavetable
&&&&POLYPHONY: ?
&&&&ROM: none
&&&&RAM: none
&&SNR: 85dB?
Sound Blaster 32
&&WAVE:
&&MIDI:
&&&&TYPE: hardware wavetable
&&&&POLYPHONY: 32
&&&&ROM: 1MB
&&&&RAM: none (expandable to 28MB 32-pin SIMM)
&&SNR: 85dB
&&FREQUENCY RESPONSE: 20Hz - 20kHz
Sound Blaster AWE32
&&WAVE:
&&&&3D AUDIO: 3d stereo, positional stereo surround
&&MIDI:
&&&&POLYPHONY: 32
&&&&ROM: 1MB
&&&&RAM: 512kB (expandable to 28MB 32-pin SIMM)
&&SNR: 85dB
Sound Blaster AWE64
&&WAVE:
&&MIDI:
&&&&TYPE: hardware + software wavetable
&&&&POLYPHONY: 32 + 32
&&&&ROM: 1MB
&&&&RAM: 512kB (expandable to 24MB 32-pin SIMM)
&&SNR: 90dB
&&FREQUENCY RESPONSE: 15Hz - 50kHz
Sound Blaster AWE64 Gold
&&WAVE:
&&MIDI:
&&&&ROM: 1MB
&&&&RAM: 4MB (expandable to 24MB 32-pin SIMM)
&&SNR: 90dB
&&FREQUENCY RESPONSE: 15-50kHz
Sound Blaster 16 PCI
&&WAVE:
&&&&3D AUDIO: none
&&MIDI:
&&&&TYPE: opl3
&&&&POLYPHONY: ?
&&&&ROM: none
&&&&RAM: none
&&SNR: 90dB
Sound Blaster PCI 64
&&WAVE:
&&&&3D AUDIO: ?
&&MIDI:
&&&&TYPE: hardware wavetable?
&&&&POLYPHONY: 64?
&&&&ROM: ?
&&&&RAM: ?
&&SNR: 90dB
&&CD AUDIO: analogue, digital?
Sound Blaster PCI 128
&&WAVE:
&&&&3D AUDIO: ?
&&MIDI:
&&&&POLYPHONY: 64?
&&&&ROM: ?
&&&&RAM: ?
&&SNR: 90dB
Sound Blaster PCI 512
&&WAVE:
&&&&SAMPLE RATE: 8kHz - 48kHz
&&&&3D AUDIO: ?
&&MIDI:
&&&&POLYPHONY: 64?
&&&&ROM: ?
&&&&RAM: ?
&&SNR: >96dB (-120dB noise floor)
&&FREQUENCY RESPONSE: 10Hz - 44kHz
Sound Blaster Live!
&&WAVE:
&&&&CHANNELS: quadraphonic
&&&&3D AUDIO: EAX 1.0
&&MIDI:
&&&&POLYPHONY: 64?
&&&&ROM: uses system RAM
&&&&RAM: uses system RAM
Sound Blaster Live! Platinum
&&WAVE:
&&&&3D AUDIO: EAX 1.0, EAX 2.0, A3D 1.0
&&MIDI:
&&&&POLYPHONY: 64?
&&SNR: 96dB
&&FREQUENCY RESPONSE: 10Hz - 44kHz (48kHz S/PDIF)
Sound Blaster Live! Platinum 5.1
&&WAVE:
&&&&RESOLUTION: 16-bit (32-bit Mixer)
&&&&CHANNELS: 5.1 surround
&&MIDI:
&&&&POLYPHONY: 64?
&&SNR: 96dB
Sound Blaster Audigy
&&WAVE:
&&&&SAMPLE RATE: 8kHz - 48kHz (reports 96kHz in system)
&&&&RESOLUTION: 16-bit (24-bit DAC, 32-bit Mixer)
&&&&3D AUDIO: EAX 1.0, EAX 2.0, EAX 3.0, A3D 1.0
&&MIDI:
&&&&POLYPHONY: 64
&&SNR: 100dB
&&FREQUENCY RESPONSE: 10Hz - 48kHz? (96kHz S/PDIF)
Sound Blaster Extigy
&&WAVE:
&&MIDI:
&&&&POLYPHONY: 64
&&&&ROM: uses system RAM?
&&&&RAM: uses system RAM?
&&SNR: 100dB
Sound Blaster Audigy 2
&&WAVE:
&&&&SAMPLE RATE: 8kHz - 96kHz (5.1 surround), 8kHz - 192kHz (stereo)
&&&&RESOLUTION: 24-bit? (24-bit DAC, 32-bit Mixer)
&&&&CHANNELS: 6.1 surround
&&&&3D AUDIO: EAX 1.0, EAX 2.0, EAX 3.0, EAX 3.1?, A3D 1.0, A3D 2.0?
&&MIDI:
&&&&POLYPHONY: 64
&&SNR: 86dB - 106dB
&&FREQUENCY RESPONSE: <10Hz - 46kHz (96kHz S/PDIF)
Yes, it’s my fault.
Reply 1 of 5, by twins73
Sound Blaster WAVE: SAMPLE RATE: 5kHz - 22.1kHz RESOLUTION: 8-bit CHANNELS: monaural 3D AUDIO: none MIDI: […]
Sound Blaster
WAVE:
RESOLUTION: 8-bit
CHANNELS: monaural
3D AUDIO: none
MIDI:
TYPE: fm
POLYPHONY: ?
ROM: none
RAM: none
SNR: 48dB
CD AUDIO: none
Well, from a book I bought a long time ago about Sound Blaster cards :
Sound Blaster 1.0 & 1.5 :
WAVE :
SAMPLE RATE : 4Khz - 15 Khz (Recording)
4Khz - 24 Khz (Playing) [Would have thought it was 22.05 ... ]
MIDI :
11 mono fm voices
Difference between 1.0 & 1.5 are the presence of 12 stereo C/MS channels on the 1.0 which were removed on the 1.5 making it cheaper.
Sound Blaster 2.0 :
Same as above except SAMPLE RATE for playing was bumped up
to 44.1 Khz (audio CD) -> 4Khz - 44.1 Khz (Playing)
Sound Blaster Pro 1.0 :
WAVE :
SAMPLE RATE : 4Khz - 22.05 Khz (Stereo Playing)
4Khz - 44.1 Khz (Mono Playing)
MIDI :
11 stereo fm voices
Sound Blaster Pro 2.0 :
Same as 1.0 except replaced fm chips with Yamaha OPL3 chips.
I hope this help.
Stephane
Reply 2 of 5, by Snover
Thanks, Steph! (I can call you Steph, right?)
I've integrated those changes into the list, as you can see.
Oh, curiously, (ignorant me) what did the Creative Music System channels actually DO (and why was it okay to remove them?), and what is the difference between their FM chip and the OPL3?
I'd also like someone to please clarify the 3D audio modes, particularily those APIs that are in the Audigy 2 and Extigy.
Yes, it’s my fault.
Reply 3 of 5, by twins73
Well, I can bring one answer to the C/MS question :
Before doing Sound Blasters, Creative Labs did also another
card known as the Game Blaster. the C/MS chips are what
make the Sound Blaster 1.0 compatible with the Game Blaster.
Note that the SB1.5 and 2.0 did not come with C/MS chips but
you could add them and therefore get the compatibility with
the Game Blaster.
I see you coming with a next question : So what is the Game Blaster ?
Well I do not know much since I have always been interested in
digital audio so better forwarding you elsewhere such as :
GameBlaster Sound Card
For the FM chips and OPL3, FM chips were OPL2 and OPL3 were just
an improvements over it.
OPL2 (YM3812)
* two modes: melody mode (9 channels) and percussion mode (6 channels of melody and 5 channels of percussion)
* 2 operators per melody channel (various in perccusion channel)
* each operator has ADSR envelope, 64 levels volume, vibrato and tremolo LFOs
* operators can be connected in FM (Frequency Modulation) or AM (Additive Modulation) mode
* 8 octaves tone resolution
* 4 waveforms (sinus and sinus-based waveforms)
* mono
OPL3 (YMF262, YMF289)
* compatible with OPL2
* 18 channels of 2-operator FM/AM synthesis
* 4-operator mode (up to 6 channels)
* 8 waveforms (square too!)
* stereo (only left/central/right settings per channel)
* much faster (smaller delays between register writes needed)
(Information badly copied and pasted from the following link :
http://www.astercity.net/~malf/welcome.html )
For your other questions sorry, I am a bit out of date 😉 but
I found the following :
From Tom's Hardware Guide you can read :
... Today's games for the most part use Direct Sound 3D, but also support EAX, some in version 2.0. It has to be made clear that Creative has also made EAX accessible to other soundcard manufacturers. The new norm will be reserved for Audigy, at least for now. In a way, it's the EAX 3, renamed Advanced HD. ...
I invite you to read the full article.
Anyway from this part you can guess that there is no EAX3.0 or EAX3.1. There is just EAX Advanced HD. And if you are really
eager to learn more about it perhaps try the EAX website ?
Hope that all this helped more than confused you 😉
Finally you can call me Steph or Stef but not StephanIe 😠 😉
Stephane
Reply 4 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
don't know if it is really relevant, but the AWE 64 (normal) had an IDE controller for a CD-Rom drive on board.
Always one of the resources I threw out on Win9X
