Reply 1060 of 1231, by sharangad
Does anyone know if the Rendition enhanced tracks had issues on original hardware?
https://www.youtube.com/@sharangadayananda
Reply 1061 of 1231, by sharangad
The socket comms lag might just be because vs 2022 taking ridiculous amounts of cpu idling.
Reply 1064 of 1231, by sharangad
robertmo3 wrote on 2024-04-18, 16:44:
the easiest way to tell if fog responsible is to turn off fog
If I force fog on permanently it renders correctly. The in game views do, but the replays are blacked (fogged) out.
Reply 1065 of 1231, by sharangad
robertmo3 wrote on 2024-04-18, 14:45:
how about this
https://www.msys2.org/
If I build with that, I think it'll need msys2 to run. I might have better luck with gcc for Windows that runs without msys2.
Vs2022 has become a cpu hog since theprevious patch Tuesday update. It was fine before that. I don't know for a fact that it's Vs2022 causing problems.
Reply 1067 of 1231, by sharangad
sharangad wrote on 2024-04-18, 14:21:
Nope, happens even without it.
Reply 1068 of 1231, by sharangad
sharangad wrote on 2024-04-19, 05:59:
I think I've fixed it. Timing error at startup and repeating keys (keyboard repeat).
[EDIT] Yes I have[/EDIT]
Reply 1069 of 1231, by sharangad
Tomb Raider 1 Rendition Edition:
https://youtu.be/z35ITGXTZY8
(Sorry, you're going to be disappointed). @Raven-05 is this supposed to be Lara's passport spinning around?
Reply 1070 of 1231, by Agent of the BSoD
That's all the objects on the menu constantly spinning, so yeah the passport is in there somewhere. It definitely isn't supposed to be doing that unless you're holding down the left/right button the whole time.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 1071 of 1231, by sharangad
Agent of the BSoD wrote on 2024-04-20, 01:05:
Thanks @Agent.
Reply 1072 of 1231, by chuky
I don't have it installed anymore but I think dosbox does that if you have a joystick plugged in. You need to disable the joystick in the dosbox config or something like that. I think when it's spinning, if you hold left or right on the keyboard it stops spinning.
Reply 1073 of 1231, by sharangad
chuky wrote on 2024-04-20, 01:25:
Thanks for that. I did try holding down the arrow keys but it didn't seem to do anything. Maybe dosbox /rready didn't send the keystroke through.
Reply 1075 of 1231, by sharangad
robertmo3 wrote on 2024-04-20, 04:15:
have you tried unplugging joystick?
Will try that next, when I'm back on the job.
Reply 1076 of 1231, by sharangad
Yup disconnecting the pad worked a treat:
Reply 1077 of 1231, by sharangad
https://youtu.be/x6PpQG-jpEM
There's no sound for some reason.
[EDIT] Apologies for boring videos. I just get a kick out of seeing it.
Reply 1078 of 1231, by sharangad
Someone with a Rendition board, try running this from Windows and dump the output here:
https://1drv.ms/u/s!As-dKk-N73dSmG1vQYeiAvRdBuMw?e=b3NTPk
MD5: a5c11401bdfcb89c40f1fc76f91573e9
Reply 1079 of 1231, by RaVeN-05
Buffer dims 640x480 stride 81 and linebytes 1280
Buffer dims 800x600 stride 81 and linebytes 1280
Buffer dims 1024x768 stride 81 and linebytes 1280
Buffer dims 1280x1024 stride 81 and linebytes 1280
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
