PCem emulation speed is terrible
First post, by FIN_K89i
hello im using pcem on my aspire 5 whit a 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz 2.80 GHz NVIDIA GeForce MX450 win11home end 16 gb of ram end im using PCem 17 latest version from the web site end on it i use windows ME whit 128mb of ram pentium 2 at 333mh a voodoo 3 3000 sound blaster PCI 128 on a gigabyte GA-686BX end 6gb of storage end the emulation speed is terrible the sound skips end i cant play pinball proprely like how i fix this? i have hard times playing how i can fix this?
Reply 3 of 55, by eddman
Make sure Voodoo 3's render threads count is not set above 2. Change windows' power plan to "High Performance". If it still doesn't help, then it probably means your i7 is not powerful enough to emulate a PII 333; choose a slower PII. If still slow, try a Pentium 1.
It must be noted that certain games have performance issues with v17, regardless of the chosen emulated CPU.
Reply 4 of 55, by Jo22
eddman wrote on 2023-08-17, 12:09:
I think the same. On an AMD Athlon 64 X2 from 2006 I was able to emulate an 486DX-50 with WinBIOS machine setting at full speed.
On an Mac Pro with Xeon processors, I was able to emulate a Pentium Overdrive 63 with WinBIOS machine setting already (at full speed).
A Pentium 133 MHz was possible, too, with some performance drops.
On an i7, depending on its single core performance, a fast Pentium MMX (166 or higher) or a Pentium Pro might be possible, even! 😃
The Pentium Pro is worth a try insofar, because it had a close relationship with the Pentium II architecture.
PS: Here's a tip. Older OSes like DOS or Windows 3.1x and Windows 9x do use idle loops.
That causes VMs to run at 100% CPU sage, even if nothing is happening.
Same problem exists for more advanced emulators, in theory.
To fix that problem, there are utilities that can be used.
- DOSIDLE, for DOS. Uses APM BIOS or the HLT command to let the CPU sleep.
The HLT instruction is available since late 486 processors.
- WQGHLT, for Windows 3.x; it is a CPU load reduction tool that's implemented as a VXD.
It will run on ring-0 and needs Windows running in 386 Ehnanced Mode.
- Raine/AmnHLT 1.0, for Windows 9x.
Technically, these systems should have powersaving featues on their own (POWER.EXE on DOS, APM support in Windows 3.1x setup etc), but they rarely work for whatever reasons. 🤷‍♂️
Reply 5 of 55, by FIN_K89i
bro wth i need a nasa pc or what? i dont see how emulating can be that heavy
Reply 7 of 55, by eddman
FIN_K89i wrote on 2023-08-17, 17:30:
Bruv, I know that was a joke, but NASA's fastest supercomputer cores are sub-3 GHz Cascade lake (Skylake-class) and Zen 2 based, so they'll run PCem even slower than your i7.
Proper low-level emulation of such increasingly complex processors is quite demanding.
Reply 8 of 55, by mothergoose729
Feel free to build a better PC emulator yourself
Reply 9 of 55, by FIN_K89i
feda wrote on 2023-08-17, 17:41:
With PCem? Yes, you do. It requires powerful single-threaded performance.
Bro you know if there are more light emulators like PCem because my i7 i think that is cuite powerfull like standard games run ok the only less performance pice of my pc is the GPU but for the games that I play is enough
Reply 10 of 55, by DosFreak
Bro, https://www.youtube.com/watch?v=c8AP4qDBfqo
You need to try virtualization programs such as virtualbox or vmware if the game you are trying to play which you haven't named cannot run natively on your host os.
Make your games work offline
Reply 11 of 55, by FIN_K89i
DosFreak wrote on 2023-08-18, 14:36:
Ye but virtualbox doesn't emulate CPU GPU end everything
Reply 12 of 55, by BEEN_Nath_58
FIN_K89i wrote on 2023-08-18, 14:52:
You answered yourself why emulation is heavy
Reply 13 of 55, by feda
FIN_K89i wrote on 2023-08-18, 14:21:
Lol bro, your weak little laptop CPU is 3x-4x slower than desktop processors and just barely faster than my 10 year old quad core 3570k. Forget about it.
Reply 15 of 55, by FIN_K89i
feda wrote on 2023-08-18, 16:39:
Bruh I would buy a desktop but here in Sicily power is Reliable like a 1983 panda one day works the next who knows
Reply 16 of 55, by eddman
Maybe cool it a bit with the "bro" and "bruh".
That model actually has a good performance overall; considerably higher than a 3570k.
The problem is that those PCem settings are too high for it. It is also possible that the laptop doesn't have a very good cooler and thermal throttles.
The wrong windows power plan could also have a major effect, specially with U class Intel CPUs, but the OP never responded to that.
Reply 18 of 55, by eddman
feda wrote on 2023-08-18, 17:50:
Not according to benchmarks it doesn't.
Compared to what which exact models? Obviously it cannot get close to modern desktop i5-i9 or Ryzen, but compared to other contemporary quad core processors it's quite alright. It's faster than my Ryzen 2600 per core, and probably still is with workloads up to 4 threads. It's much faster than a 3570k.
PCem uses 4 threads when voodoo 3 is set to 2 render threads, so you don't need more than 4 cores anyway. That i7's per core performance is ok, just not high enough for top Pentium 2 emulation.
I just don't get why a P2 is even needed. A pinball game should run fine with a P1, unless it's an XP era game which in that case it'd be better to run it directly on the computer with a wrapper like dgvoodoo.
Reply 19 of 55, by Jo22
^This.
Personally, I started with ancient/lower-end PCs most of the time (but without saving on RAM expansion)..
From what I can tell, a Pentium MMX 166 is good enough for many things, including Windows XP (SP0/SP1).
I ran emulators on such a physical PC back in ~2000-2004, even.
Windows 98SE is even less demanding.
A Pentium 90 or similar will work without pain.
So you could use a 486 machine setting instead with a Pentium Overdrive, even. The "POD83" is fine.
Anyway, these are just my two cents.
I'm a bit disconnected with the current tech.
So let's just think of the saying "less is sometimes more".
