First post, by GloriousCow
I'm confused about the SOM field in the End Horizontal Retrace Register.
Ferraro has this to say about it:
Determines whether an odd or even memory address should be used as the first memory address after a horizontal refresh
=0 Start at an even memory address
=1 Start at an odd memory address
IBM's document says:
Start Odd/Even Memory Address-This bit controls whether the first CRT memory address output after a horizontal retrace begins wi […]
output after a horizontal retrace begins with an
even or an odd address. A logical 0 selects even
addresses; a logicall selects odd addresses. This
bit is used for horizontal pel panning applications.
Both of these descriptions are a bit ambiguous. Take for example, Dangerous Dave in the Haunted Mansion.
Dave's title screen starts out with a CRTC start address of 0.
170.76 KiB
dangerous dave panning #1
The screen then pans to the right, incrementing the start address to 40, one byte at a time.
138.73 KiB
dangerous dave panning #2
However, the scrolling as i have implemented it is very jerky. I would expect a sequence of (start address, pel panning) updates to be (0,4)(1,0)(1,4)(2,0)(2,4) and so on, to effect a smooth pan.
Instead i'm seeing: (1, 0)(2, 4)(3, 4)(4, 0) ... it doesn't make much sense.
I was wondering if somehow the SOM bit is affecting the memory start location. If SOM==0, then we should start each scanline on an even address - so what effect does that have when the crtc start address itself is odd, like ==1?
We know that pel panning is not latched - it can be updated per scanline (as demonstrated by Beverly Hills Cop's wiggly text effect)
I saw mention of preset row scan being used for scrolling operations, but in this effect it is set to 0 and never updated.
There's also nothing going on with display enable skew or horizontal retrace delay.
What is the secret i'm missing to smooth scrolling?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 1 of 4, by GloriousCow
Well, as soon as I post this, I find this thread: When Does VGA latch the start address register
Changed from latching the start address at vertical total to latching it at vsync, and now the scrolling is smooth. Imagine that.
Would still love to know what the heck the SOM bit is supposed to do, though.
Reply 2 of 4, by keenmaster486
I think there's been discussion about this before with reference to clone EGA cards not scrolling Commander Keen correctly.
World's foremost 486 enjoyer.
Reply 3 of 4, by GloriousCow
keenmaster486 wrote on 2024-02-15, 04:40:
Because they latch the start address at a different time?
Reply 4 of 4, by keenmaster486
Something like that. I can't remember exactly. I think the info is in one of these threads:
Why does Commander Keen 4-6 hardware scrolling glitch on ATI (Mach) PCI video cards?
Pulling my hair out with EGA programming.
VGA behavior when "scrolling over the edge"
