Dead AWE32?
First post, by retro games 100
Hello. I've just bought an AWE32 (CT3900, non-PnP). I'm so disappointed with it because I think it's dead. After I insert the card in to the ISA slot, when I turn on my PC, I get no BIOS POST message. If I remove the card, everything is OK with my machine.
I have tried to re-insert the card in to the ISA slot a few times, and also tried all other available ISA slots. I have also tried another working AWE32 card, and that works OK in my motherboard.
I do not understand what some of the jumpers do on this non-PnP CT3900 model, but would that really stop my PC from POSTing?
Thanks very much for any help on this matter, best regards, Robert.
Reply 1 of 8, by Amigaz
Maybe it's set to IRQ7 and conflict with the LPT port but you should get a IRQ conflict error message then if your PC is modern enough
Never had any problems with a non booting PC just because a legacy card is defect...it should boot anyway.....odd
Reply 2 of 8, by StickByDos
There is the IDE connector of the awe32 which can conflict with the one of the mobo
Many old mobos / io-cards only have 1 ide port, your awe32 ide port may be jumpered as 2nd ide port
Type win to loose the power of your computer !
Reply 3 of 8, by retro games 100
To Amigaz:
I currently have Parallel port disabled in BIOS. I might try enabling it just to see if it makes a difference.
To StickByDos:
On my CT3900 model, there are 2 IDE interfaces. There is also a cluster of 3 jumpers near them that reads:
IOCHRDY
IDE100
IDE101
I don't know how to set these jumpers. However, I have tried this jumper configuration:
IOCHRDY Open
IDE100 Closed
IDE101 Closed
(No success.)
Best regards, Robert.
Reply 4 of 8, by retro games 100
PS, I'm sorry I forgot something:
Also, there is another cluster of 5 jumpers next to the ones I already mentioned. These read:
IDE IRQ
10
11
12
14
15
Currently, all 5 jumpers are Open.
Reply 5 of 8, by StickByDos
Jumpers here
According what you said, ide is disabled
You said "2 IDE interfaces" , only one is ide, the 2nd (panasonic) is an old interface for cdrom (not compatible with ide cdrom)
Have you tried it on another computer ?
Have you reserved irq in the bios set-up for legacy isa, if your bios assign irq 5 or 7 to pci device, it can conflict with your non-pnp awe32
Reply 6 of 8, by retro games 100
Thanks very much for the jumpers info.
I've just tried the AWE32 in another computer, and I get exactly the same symptoms - no POST at all - the PC will not boot-up.
I suspect there may be something really wrong with the card. I've tried cleaning the ISA pin contacts that run along the ISA slot, but that did not help.
Reply 7 of 8, by 5u3
I agree. This looks rather bleak.
Maybe we can spot something if you make a high-res photo of the card (front and back) and post it here. But it may not be worth the trouble.
Reply 8 of 8, by retro games 100
I'm really sorry but I can't upload a good photo of the card - I just haven't got a decent enough camera to take a proper close-up picture of it.
I tried the card in 3 different mobos, and all 3 failed to POST, so I really think the card was significantly damaged in some way.
I have subsequently disposed of it.
