Strange thing
First post, by abyss
Strikebase has similar requirements to quake 1 but strikebase runs fine at 7500 cycles. I think dosbox doesn't fully support protected mode. Strike base is a protected mode game and it runs at regular speed and has similar requirements to quake 1. Another strange thing if you play wacky wheels on a xp without dosbox you will be able to get sound blaster sound that is 100% perfect and general midi sound that is 100% perfect but try any other dos game without dosbox with soundblaster and you will get absolutely terrible sound.
Reply 1 of 19, by wd
Rank DOSBox Author
DOSBox Author
What's missing? Are you sure you know what pmode is?
Maybe send an email to gates.
Reply 2 of 19, by abyss
I know what protected mode is. I still think dos box does not fully support protected mode as strike base is a protected mode game with similar requirements to quake and it runs with 7500 cycles at normal speed but quake runs too slowly no mattar what you do. Doom runs great at 7500 cycles. tomb raider,blood,duke 3d and quake and many other protected mode games run too slowly though.
Reply 3 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
wait for the next version
and you might understand what protected mode is ,but you don't understand why
certain games are slow in dosbox.
Water flows down the stream
Reply 4 of 19, by eL_PuSHeR
You are wrong. You can't compare two different games regardless of same engine. I think this has nothing to do with protected mode unless *again* you are comparing different extenders (dos4gw and phar-lap) for instance.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 19, by wd
Rank DOSBox Author
DOSBox Author
Well if he says pmode is wrong, i'm sure he has founded reasons for this.
Reply 6 of 19, by abyss
strike base is a dos 4gw game and tomb raider is a dos 4gw game yet strike base runs at normal speed with only 7500 cycles and tomb raider runs slowly at any cycle count and 10 frameskip and their is many dos 4gw games with lower requirements that will run too slowly in dosbox. duke 3d and blood and quake run too slowly yet why do they have similar requirements to strike base. Strike base runs nicely at only 7500 cycles.
Reply 7 of 19, by wd
Rank DOSBox Author
DOSBox Author
And what has this to do with pmode not being fully supported?
They all run, don't they?
Even if they all use the same extender doesn't mean they're all
exacly equal (that would be boring, huh?) .
If you "just" want to know how to speed them up, read Qbix's posting.
Reply 8 of 19, by DosFreak
You cannot compare box requirements. Box requirements have nothing to do with actual gameplay. The only way you can know if a game works correctly is by installing it on the actual hardware and using it. Just because one game say's it requires a 486DX and another say's it requires a 486DX does not mean that they both will run fine on the same hardware. System Requirements have never and will never be accurate due to the many variables involve in computer hardware.
Make your games work offline
Reply 9 of 19, by eL_PuSHeR
Also, you cannot compare a 3D game with a 2D.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 10 of 19, by abyss
I was not comparing 2d games to 3d games all the games i mentioned are 3d.
Reply 11 of 19, by wd
Rank DOSBox Author
DOSBox Author
So what now? What in pmode is broken in your eyes?
Reply 12 of 19, by abyss
Can someone please tell me why many games with similar requirements to strike base run too slowly no mattar how many frameskips and cycles you put on yet strike base runs great.
Reply 14 of 19, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Because your 500MHz computer is too slow.
1+1=10
Reply 15 of 19, by wd
Rank DOSBox Author
DOSBox Author
Maybe heavy fpu games like Quake are just comparable with easy voxel
games like strike base...
Reply 16 of 19, by abyss
Strike base is a 3d game that is somewhat similar to dune. almost all Games from 2002 and later run slowly or crash when a lot is going on. I use dos box 0.63,0.65,0.60 and 0.58. nfs hp2 runs too slowly too be considered playable. nfs underground runs too slowly too be considered playable, morrowind runs slowly but it is decent enough to be playable but it crashes when a lot is going on. I have a crappy video card. I can play the sims and roller coaster tycoon 2 and many others perfectly. and although my video card sucks for newer games it is great for dos games. My computer can run some dos games that won't run on other xp's. My computer can play windows 95 games without troubles.
Reply 17 of 19, by ErikGG
http://en.wikipedia.org/wiki/Protected_mode
In short : A way to offer more features to the game, like more memory and so on...
If DOSBox wouldn't have supported protected mode for some part then protected mode games wouldn't even run on DOSBox.
Speed and protected mode have no relation what so ever. Well, ... the only relation is : Protected mode is slower then all real mode games. The reason for this is that protected mode offers more overhead to games.
Now the part why Strike base is slower then Quake. First, Strike base is a Voxel game.
Voxel games are more or less 3D. They resemble 3D but they are not. They are a trick that was used to simulate large environments. These graphics engines where actually integer based and optimised that way. These engines don't do anything actually that is wastefull, I mean every pixel is only looked at and drawn once. This is what makes it a pixel based look. Or better said, a strawfield look. In these engines there are parts that get a real 3D handling and these are always small things like houses and things. But I'll handle that later on.
Games using such engines are easy to spot, but here are a couple :
Outcast
Swift 3D
Next we have Quake. This one got even the E3 anouncement as the first real 3D engine.
These engines are really nice to look at but if you know what is going on then you really know that your driving a Hummer ( 1 on 10 mileage) in stead of an Audi A2 ( 4 on 100 mileage ).
Ok now the real science. A real 3D engine actually does nothing else then execute for every frame, for every corner ( point ) in the game three blocks of calculations. These are the basic ones, every real 3D game performes these no matter what the looks.
Block A (round X axes):
x'=x
y'=y*cos(ang)-z*sin(ang)
z'=y*sin(ang)+z*cos(ang)
Block B (round Y axes):
y'=y
x'=x*cos(ang)+z*sin(ang)
z'=-z*sin(ang)+z*cos(ang)
Block C (round Z axes):
z'=z
x'=x*cos(ang)-y*sin(ang)
y'=x*sin(ang)+y*cos(ang)
Ok thats that, with these functions you can rotate a single point round a center point. These functions are not integer based but floating point based. There are even gradations in persision for these, single, double and extended, each being slower then the other. For quake these are with a single point persision and maybe even double.
If we would only make an engine using these functions you get wireframe games, like there are out there ( Elite ). But with Quake there are actually more things to add like texturemapping, there are even speed/percision gradations in these, for the textures.
If you look a the screen then you might be able to count the number of corners in a game, but you need to remember that a square isn't actually a square but a combination of triangles. So for a square you might have four to an unmentionable number of triangles forming together a square. Most viewable in Tombraider while rotating round looking at the textures edges in low res mode.
Every triangle in the loaded game is rotated every drawn frame and every triangle in the field of view is drawn, even the ones not visible and behind other drawn triangles.
So,
* A real 3D game is a hog on CPU/FPU power, graphics power and memory. Uses real floating point and isn't really very optimised and does wastefull things like drawing things that don't need to be drawn.
* Strike base is doing nothing wastefull and uses an integer based engine every frame a few values get calculated and based on these the frame is drawn.
The requirements for Real 3D games are much heavier then Voxel games. If the game box says that both games would need the same CPU power then they said it for a pentium based class CPU. But with DOSBox this flies out the window completely. DOSBox has a software CPU and therefore doesn't really do everything as fast or comparible fast as it was on a pentium.
So looking at the requirements of a game isn't enough for DOSBox, as was in the "real" pentium times. You need to look at what type of game it is, Voxel based, RayCasting based, 2D based or 3D based, and ofcourse the needed CPU power in real life.
The explenation for Strike base being so fast and Quake being so slow is because of the following factors :
Strike base : Voxel engine (integer based), not wastefull.
Quake : Real 3D engine (float based), wastefull.
Hope this solves the "mistery" around the slowness...
Erik.
Read the new FAQ.doc
Reply 18 of 19, by leileilol
7500 cycles isn't enough for Quake anyway. You'll need like 60000 cycles for that to be playable at the least.
/me runs around quake in dosbox at around 40fps wee protected mode games work
oh and dosbox 0.63 and prior don't support protected mode games well (or not at all) so yeah don't even bother trying in those versions.
Reply 19 of 19, by wd
Rank DOSBox Author
DOSBox Author
Hahaa play win95 games then or dune in dosbox.
Closed.
