wow !!!!!
First post, by kruwi
What a speed boost !!!!!
With 0.66 rc1 (cvs) I'm finally able to play micropose grand prix 2 (!) with almost all graphic details (svga!) on a crappy 1.6 GHz centrino Laptop!
Visit the end of the internet: www.groskreutz.de
Reply 1 of 37, by deltaphc
Indeed. Even System Shock and Blood run smoothly. I love it.
Great job, dosbox devs!
Reply 2 of 37, by abyss
Wait dosbox 0.66 is out. How come it is not shown at the dosbox site.
Reply 3 of 37, by leileilol
There's still bugs to work out, like Strike Commander sucking.
Reply 4 of 37, by Xerxes
Yes, and Stonekeep crashes (only with dynamic core i believe).
Intel C2D E8500@3,6 Ghz, DDR2-800 2x2Gb Ram, MSI Radeon HD6950 Twin Frozr II/OC, Asus P5E Deluxe, Asus Xonar DX, HDD: WD 500AAKS x2, Windows 7 Professional 64bit
Reply 5 of 37, by Qbix
Rank DOSBox Author
DOSBox Author
up to date plain cvs compile ?
thought that the dynamic code was quite stable.
Water flows down the stream
Reply 6 of 37, by Xerxes
Yes, i'm talking about newest CVS here. The dynamic core was stable (in Stonekeep) in 01.05.2007 cvs by ykhwong, but not now (neighter ykhwong or plain cvs from cvscompile.aep-emu.de).
edit: this is screenshot from crash - dynamic core, auto cycles, DOSBox 0.66rc1 CVS (02/06/2007) by ykhwong
Reply 7 of 37, by wd
Rank DOSBox Author
DOSBox Author
What date is the aep build you used?
Reply 8 of 37, by Xerxes
CVS from 06.02.2007 but last change was made 2007-02-04 (according to changelog).
Reply 9 of 37, by wd
Rank DOSBox Author
DOSBox Author
Do you know when it approximately last worked fine?
Reply 10 of 37, by Xerxes
In 01.05.2007 cvs by ykhwong, i'm 100% sure because i actually finished this game on it...
edit: so something went wrong between 01.05.2007 and 01.21.2007 ykhwong's cvs
Reply 11 of 37, by kruwi
Strike Commander causes troubles for me as well (erratic mouse behaviour) lately. My enthusiastic "wow!!!" statement was more or less restricted to speed improvements.
As some of you know I have submitted a bug report about stability problems with the dynamic core and win 3.x myself. It's quite probable that these problems are not "win 3.x only problems", but that more or less general problems of the dynamic core.
Xerxes' timetable (between 07.01.05 and 07.1.21) matches the results of my own testing.
Reply 12 of 37, by Xelasarg
You are certainly right with your "wow!!!".
Duke3D runs like a charm in 800x600 - just compare it to the official .065 release.
Feels like a 1000% speed improvement. 😁
"What's a paladin?!"
Reply 13 of 37, by valnar
This statement is correct in many ways. My Windows 3.1 works fine in ykhwong's 1-5-2007 build, which is my current favorite. It worked on previous builds too, but not the latest 1-21-2007 build without crashing.
Robert
Reply 14 of 37, by wd
Rank DOSBox Author
DOSBox Author
Nobody cares what's your favourite. If you think it's a bug, test it in a clean
cvs and, if possible, try to determine the date when it's broken. Currently
there is no useful information about those windows problems.
Reply 15 of 37, by valnar
wd wrote:
Nobody cares what's your favourite. If you think it's a bug, test it in a clean cvs and, if possible, try to determine the date […]
Well, other than pointing out that you may try the same build(s) to see if it happens to you under the same circumstances.
I am not a tester, or a developer, nor do I claim to be. I'm a user. I only wish to add some weight to a problem and point out that it happens to more than one person.
-Robert
Reply 16 of 37, by wd
Rank DOSBox Author
DOSBox Author
Well then, i have a good bunch of win3x installations, some running large
apps as the previously mentioned delphi and others. All just work fine.
The is really nothing i can do with such rough information (the timeframe
you posted has a good 50 commits).
Reply 18 of 37, by kruwi
The "strange thing" about these problems (which I was the first to mention in this forum) is that they do not occur if I do a fresh win 3.x installation ... .
I have done a lot of testing abou this, trying to find the roots of the problem with the help of wd. But at the moment I am still as clueless as before.
To valnar:
But I have done these testings. And I'm NO TESTER and NO DEVELOPER. Just a USER, like you. So, is there any chance that you could do some testings as well? It would be very helpful if you could use some of the builds mentioned by DOSFREAK and experimentate a bit, using builds from differente dates and compare them. It's important you use these builds and not yhkwong's for testing because they are clean and do not contain additional patches.
This would be very very helpful!!!!
Reply 19 of 37, by wd
Rank DOSBox Author
DOSBox Author
That's why i'm (at the moment) convinced that it's a buggy installation,
which is (most likely) caused by an older dosbox version but was not
visible in those versions.
If somebody can post reproducable steps how it happens after installing
win3x (preferably using the dynamic core only) then for one this points
at a bug in the current dosbox versions AND gives valuable information
for further debugging.
