First post, by fsmith2003
- Member
I have the below card. The larger capacitors are marked as 10, 6s, then some random numbers (0G2) which I am sure is a date code of some sort. The smaller 2 capacitors in the bottom left though are marked 22, N, 6. I know the larger ones are 10uf 6V but what would the smaller ones be? Are they 22uf 6V or would it be 22nf 6V because of that N marking on there?
