First post, by Queenofdragons6
As someone who is very new to DOSBox, how does one get Millennia: Altered Destinies' music to play when playing the game via DOSBox?
Run: INSTALL.BAT
Select Autodetect, it should show Sound Blaster 16, otherwise select it manually:
* Select Digital as Sound Blaster 16 with PORT=220, DMA=1, IRQ=7
* Select MIDI Device as Sound Blaster 16 with PORT=388
He may be asking about the General MIDI music the game supports.
Update: I've found some promising MIDI player emulators to use such as Munt and CoolSoft VirtualMIDISynth, but now I can't even get the game to run. When I try to run the mil.bat file, DOSBox, DOSBox Staging, and DOSBox ECE get stuck on "Using "HMISET.CFG" for Sound/Music Configuration."
And the DOSBox Status Window shows a long list of variants of:
Illegal read from e001[xxxx], CS:IP 180: 2057fc
Another update: I have now figured out how to play the game with music.
