First post, by fsmith2003
- Member
I have recently obtained a DTT3500 5.1 speaker set with no digital din cable and a FPS2000 set with one. My question is, is the din to mini jack digital cable for each set the same cable or is there a difference since the FPS2000 is just 4 speakers with subwoofer but the DTT3500 has a center channel?
I have an Audigy 2zs that I hooked up the DTT 3500 to using the FPS2000’s din cable but get no center channel audio but the other 4 do work when preforming a speaker test. This is why I was wondering if there is some difference.
