First post, by Rammsteiner
Hi !!
My english is not well but i will try to explain my problem. I want to play Millenia with DOSBOX. It works, but only the intro, after playing the intro the pc crashed and he said "looking for cd ..."
i will send u a screenshot ...
i have full sound, i try to play it with VDMSound ...
In this forum here was a post how to install VDMSound with milenia, but it doesn`work because there is no VDMSRun.bat after installing VDMSound.
Millennia
"... post of saladpuncher
Step 8: Choose the Program tab. Type "C:\Program Files\VDMSound\VDMSRun.bat" C:\WINDOWS\system32\command.com in the Cmd Line text box. Use the quotes. Working text box should say C:\WINDOWS. "
can you help me ?
Reply 1 of 12, by MiniMax
Rank Moderator
Moderator
Rammsteiner - You either use VDMSound or you use DOSBox. You don't use both.
Which one do want to use?
_________________
Reply 2 of 12, by Rammsteiner
i want to use dosbox ... that porgam i understand ...
Reply 3 of 12, by MiniMax
Rank Moderator
Moderator
Please tell us
  1. If you have made any changes to the DOSBox configuration.
  2. How you mounted the emulated drives.
  3. How you installed the game.
  4. Configured it.
  5. Started it.
_________________
Reply 4 of 12, by Rammsteiner
Hi !!
I did no changes to DOSBOX. I installed the game with dosbox. My mounted drives are e (hard disc) and j (cdrom) ...
i use D-Fend to understand DOSBOX
GAMEEXE: E:\TAKE2\MILLENIA\MIL.BAT
INSTALLEXE: J:\INSTALL.EXE
u want to know more settings ? plz tell me wich one ...
Reply 5 of 12, by MiniMax
Rank Moderator
Moderator
I have attached a little file, db-info.bat that I would like you to save as
E:\TAKE2\MILLENIA\db-info.bat
Then change the GAMEXE
from E:\TAKE2\MILLENIA\MIL.BAT
to E:\TAKE2\MILLENIA\db-info.bat
and report back here on the mounted drives, and the configuration settings.
_________________
Reply 6 of 12, by Rammsteiner
i have done it but i don`T understand your last sentence ...
i have changed the exe but i dosen`t work ... same bug ...
Reply 7 of 12, by MiniMax
Rank Moderator
Moderator
Thanks for the screenshots Rammsteiner. I don't know why the game don't work for you. I suspect it has something to do with the way you installed and configured it.
Would you mind starting all over with the installation of Millenia? But this time, I want you to do it a little different.
Create a folder for the Millenia in your My Documents (Meine dokumenten ?) Something like
E:\Documents and Settings\Rammsteiner\My Documents\DOSBox-games\Millenia
In D-Fend, mount the DOSBox-games\Millenia folder as drive C (not E), and mount your CD-ROM as drive D (not J). After mounting, you should have
Game = EXE: E:\Documents and Settings\Rammsteiner\My Documents\DOSBox-games\Millenia
\MIL.BAT (Letter = C)
Install EXE: J:\INSTALL.EXE (Letter = D)
With C and D mounted, run the installer again.
_________________
Reply 8 of 12, by MiniMax
Rank Moderator
Moderator
Maybe also update to D-Fend v3 beta?
_________________
Reply 9 of 12, by MiniMax
Rank Moderator
Moderator
Another thing: If you press Alt + PrtScr while taking screenshots, you only capture the window, not the whole screen.
And don't save the pictures as JPEG's. Save them as PNG's or GIF's.
_________________
Reply 10 of 12, by Rammsteiner
it works perfect after changing letters, thx u a lot for help ...
Reply 11 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
Minimax: Gus=false will skip the joystick section.
Water flows down the stream
Reply 12 of 12, by MiniMax
Rank Moderator
Moderator
Thans Qbix - will be fixed in 1.0.2 😅
_________________
