First post, by mekamayhem
Would anyone know what the USB header pin out for this motherboard (Abit AB-IT 5V)? Nothing is mentioned in the manual from what I can see.
It's a 16 pin header with the second pin blank.
Thanks,
Thanks,
I believe you had to use some kind of bracket that was sold with the board. If I were you I'd try to figure out where's the + and the - and then try to figure out which pin is D+ and which pin is D- by trial and error.
Then tell us which pins are which 😀
I see that explains the lack of information. I shall work it out and let you all know 😁.
Thank you ,
Are you sure that the motherboard model is (Abit AB-IT 5V)? I can't find it anywhere.
yeah although It's not an easy one to find. I found the manual here
https://www.manualslib.com/products/Abit-Ab-I … 5v-9615731.html
We have it on uh19 http://www.win3x.org/uh19/motherboards/103
By the way would you like to help us and send us a good picture of the motherboard ? (With just the board, no cables in the way, no cards, etc and good lighting) ?
Motherboard
Thanks !
Sorry for necro post, but I have reverse engineered the pinout on my AB-SM5 and somebody may find it useful.
(+5V) 1 | 2 (KEY)(D1-) 3 | 4 (GND)(D1+) 5 | 6 (GND)(GND) 7 | 8 (GND)(+5V) 9 | 10 (GND)(D2-) 11 | 12 (GND)(D2+) 13 | 14 (GND)(GND) 15 | 16 (GND)
This should be applicable to these Abit motherboards (and probably some more):
AB-IT5H
AB-IT5V
AB-SM5
AB-PX5
