Got my SIMMConn yesterday. I had some random 32MB SIMMs left so it was a bit of a shot in the dark, but so far I couldn't spot any issues with this SIMM - but I only tested it with Imago Orpheus, only using a fraction of the memory (as it's an AWE64 Value, most tracks previously didn't play properly because they used more than 512KB of samples - so I can confirm that the SIMM is definitely being made use of). The SIMM has a number of NEC 424100-60 and 4217400-60 chips, 24 in total (so I suppose it's 16 regular memory chips + 8 chips for parity?). Judging from the labels, the part number of this SIMM appears to be Compaq 139973-002. I have attached a picture of the SIMM for comparison.
