crash
Reply 20 of 36, by dbarton
>Did it crash BEFORE you installed dfend again? That is with a clean
>installation of dosbox 0.70?
I didn't try that.. Does dfend change dosbox in some way? I assume it just loaded with it as front end.
Reply 21 of 36, by dbarton
that exact message i saw full screen seems to be in the stdout.tx files, so here's a copy
CONFIG:Loading primary settings from config file C:\Program Files\dfend\Confs\spg.conf
MIXER:No Sound Mode Selected.
MIDI:Opened device:win32
Reply 22 of 36, by wd
Rank DOSBox Author
DOSBox Author
It greatly comlicates finding what causes it if you always install additional
things. Keep it at a CLEAN installation WITHOUT dfend and stuff. If that
works you might mess around with as many frontends as you like.
Reply 23 of 36, by MiniMax
Rank Moderator
Moderator
The full-screen window is the DOSBox status-window and the messages you saw are perfectly normal. But it is not normal for the status-window to fill the whole screen. It should only be slightly larger than the main DOSBox window (unless you yourself have modified the settings for your CMD-windows?).
Please don't install D-Fend yet. We need to keep it simple.
Are you saying that you can run a clean install of DOSBox just once? Next time you run it (from the CMD-window), it fails?
_________________
Reply 24 of 36, by MiniMax
Rank Moderator
Moderator
We don't know. Ask the author of D-Fend.
Remember: assume rhymes on makes an ass of u and me. Never ass-u-me. Test, examine, and know.
_________________
Reply 25 of 36, by dbarton
ok, i rebooted, ran dosbox, ran ok, but witth the annnying full screen status with that same messag i think.
then i closed dosbox, ran again, now it it crashes every time
if i reboot, will run once agin i assume.
[if you need me to i can delete it all and reinstall clean again]
Reply 26 of 36, by dbarton
oddly though, even once dosbox wotn run on its own. dfend runnign dos box works 100% of the time
Reply 27 of 36, by wd
Rank DOSBox Author
DOSBox Author
Ok PLEASE forget COMPLETELY about dfend. I don't know if it's compatible
with 0.70 and i'm sure you installed it wrong anyways as it should never
occur in the dosbox folder.
Anyways with a clean installed 0.70 dosbox that crashes, grab the readme
and go through the troubleshoot section. Especially the stuff about output=
and if you're through with it report back here.
Reply 28 of 36, by MiniMax
Rank Moderator
Moderator
Your DOSBox directory should only contain these files:
2007-03-02  12:26    <DIR>          capture
2007-03-02 12:26 <DIR> zmbv
2007-03-02 11:43 6 863 dosbox.conf
2007-03-02 11:18 326 656 SDL.dll
2007-03-02 11:18 13 312 SDL_net.dll
2007-03-02 11:18 3 107 840 dosbox.exe
2007-03-02 12:26 34 358 uninstall.exe
2007-03-02 11:03 269 AUTHORS.txt
2007-03-02 11:03 18 332 COPYING.txt
2007-03-02 11:03 2 411 INSTALL.txt
2007-03-02 11:03 20 980 NEWS.txt
2007-03-02 11:03 44 845 README.txt
2007-03-06 22:04 0 stderr.txt
2007-03-06 22:04 0 stdout.txt
2007-03-02 11:04 730 THANKS.txt
_________________
Reply 29 of 36, by dbarton
getiing closer:
ok i eleminated Dfend, rebooted and installed DoSbox again.
It does seem to work most of the time, runs my app and all (!), but I can always make it crash by switching to the status screen (which always runs in FULL screen mode for some reason)
Once dosbox has crashed, it takes a reboot for it to work again.
I can see its actually still running by looking in task manager, but killing the process does not work. Its stuck there. After a few mins the process will dosappear, but the program will still crash everytime right away until i reboot.
Any use is seeing my dosbox.conf file?
Reply 30 of 36, by dbarton
dbarton wrote:
getiing closer: […]
getiing closer:
It seeme to me that when i run dosbox it tries to first load the status page, but once that is full screen, dosbox crashes before it even loads. Is there a way to have status NOT run full screen? am i barking up the wrong tree?
If I NEVER open the staus page, dosbox seems to run just fine after a fresh reboot
Reply 31 of 36, by MiniMax
Rank Moderator
Moderator
No, this is either
1) A problem caused by the status-window going full screen, or
2) A problem with your video-drivers.
Go to Start => Programs... => Accessories. Right-click on Command Interpreter, select Properties, go to the Options tab, and select Windowed-mode instead of Fullscreen. Press Apply & OK.
Then launch the Command Interpreter with Start => Programs... => Accessories => Command Interpreter.
Now go to the top-left corner, click on the little C:\ icon, select Standard values, go to the Options tab, and again select Windowed-mode. Press OK.
(if it asks if you want this Windowed-mode to apply to all Cmd-windows, say YES).
Now try DOSBox again.
_________________
Reply 32 of 36, by dbarton
Getting MUCH better.
Now if I start my *app* in fullscreeen, it will crash when i switch away for that screen. If I start the app in a WINDOW, then alt enter to go to full screen, it seems to work most of the time. When I am FS and tab to another window and come back it has gone back to a window even if i left when in FS /full screen, so seems ok. If I remebr to go back to wondow before tabbings, seems to work fine.
I'd just run this in a window, but when i do at 1280x1024, its window is offset to the right and need to be dragged into place. Kinda awkward. Run at 1024*768 an dthe box is too small.
Is there some setting that will allow my windows 1280*1024 to open centered??
Heres that sectiomn of config since i think some of this may hekp:
[sdl]
output=overlay
fullscreen=true <-------- change to false and it wont crash so far.
fulldouble=false
fullresolution=1280x1024
windowresolution=1024x768
autolock=true
sensitivity=100
waitonerror=true
usecancodes=true
priority=higher,normal
mapperfile=mapper.txt
Reply 33 of 36, by wd
Rank DOSBox Author
DOSBox Author
where does output=overlay come from again???
Reply 34 of 36, by dbarton
its one of the choices right above, and if I dont use it, the screen sizes are smaller.. is it not ok? I tried each one and that one looked the best.
if I use none of those, my app sits in a a very small wndow in the middle of my rather large screeen.
Reply 35 of 36, by gulikoza
I've posted this in some unrelated topic on the beta board.
Dosbox does not check if overlay locking succeeded. Overlay lock will fail if the underlying direct draw surface is lost (which probably happens when the status window is set to full screen)
http://www.si-gamer.net/gulikoza
Reply 36 of 36, by dbarton
Is there some way to have my app run in a window in non overlay mode, but not be a tiny window on my large screeen?
The app is from 640*480 days, and I run 1280*1024.
