First post, by ModemBlaster
I found a motherboard (an ECS P6BX-A+) and it has a BIOS update to support >40GB hard drives. However, the update is only supported on 2MB BIOS ROMs; this same board can have either 1MB or 2MB. Could I simply pop in a different size ROM if I get a 1MB board? If so, what exact chip do I buy?
Reply 2 of 5, by retardware
just make sure the extra address pins' levels don't matter:
copy /b source.bin+source.bin target.bin
Reply 4 of 5, by retardware
Don't use EPROM, its programming works totally different.
The first one (EEPROM) should work. But you can also take any used 2Mbit chip for this which you salvaged from a dead/useless mobo.
Reply 5 of 5, by ModemBlaster
ooooooooo that's nice to know. The board I'm buying is to replace a board with faulty USB ports, so if it has a 2Mbit chip in it I could just pop it out. Thanks a bunch
