AMD-K6-2E+/570ACZ
First post, by Swapper
Hi all ...
My first post here 😀
I'm building my retro box and after deep searching I've found where to buy an AMD-K6-2E+/570ACZ for 21 € plus shipping and handling
Is this a good price?
Reply 1 of 21, by The Serpent Rider
Yes.
Reply 2 of 21, by Swapper
The Serpent Rider wrote on 2020-06-07, 14:08:
Yes.
They offer me the following:
AMD-K6-IIIE+500ACR ---> 114 €
AMD-K6-IIIE+450ACR ---> 112 €
AMD-K6-2E+/570ACZ ---> 21 €
AMD-K6-2E+/550ACZ ---> 76 €
AMD-K6-2E+/533ACZ ---> 87 €
AMD-K6-2E+/500ACZ ---> 96 €
This is weird ... how is it possible that slower CPU's are more expensive?
Reply 3 of 21, by brian105
Old stock, unupdated prices, etc.
Can I ask where you found such a high clocked 2+ for that cheap? A local store?
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 4 of 21, by Swapper
brian105 wrote on 2020-06-07, 17:01:
Sorry 4 the delay. It's from a local store but I know they do not have such stock. IMHO they have found some place over the net where they buy them and resell upon request.
I'll investigate to find out their provider and keep updated here.
Reply 5 of 21, by jakethompson1
The K6-III+ ones despite being slower, have more cache than a K6-2+ right?
Reply 6 of 21, by cyclone3d
jakethompson1 wrote on 2020-06-08, 21:37:
Yes.
K6-2+ has 128KB L2 cache
K6-III+ has 256KB L2 cache
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 21, by dr.zeissler
More cache = slower?
Reply 9 of 21, by Sphere478
The reason the others are more expensive is they are harder to find basically.
Some guy is selling 570s by the thousands on ebay right now.
Sphere's PCB projects.
Reply 10 of 21, by cyclone3d
Sphere478 wrote on 2021-12-15, 06:26:
dr.zeissler wrote on 2021-12-15, 06:23:
Not usually.
Less max Mhz stock. Highest K6-III+ is 550Mhz and that one is VERY rare.
YMF7x4 Guide
Reply 11 of 21, by winuser_pl
How about cpga321 vs super socket7. Are these basically the same? Also this 570 MHZ is 95MHz fsb, would my ss7 mobo support that?
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 12 of 21, by rmay635703
winuser_pl wrote on 2021-12-15, 21:34:
93,95 and 97mhz FSB was more of a gimmick
Even if it only supports 100mhz the chip will work just fine.
Many super 7’s support 95 however
Reply 13 of 21, by Sphere478
cyclone3d wrote on 2021-12-15, 15:14:
Not usually.
I have one. The 550 3+ is considered faster than the 570 2+
Overclocking, yeah, wouldn’t surprise me if the 570 went further.
Be interesting to see if max 550 vs max 570 was the performance winner though.
My 550 3+ seems to crap out around 630mhz on air cooling and stock voltage.
edit:
update, the 570 can now be unlocked to a 3+
enjoy 😀 you chose wisely in your cpu choice.
Reply 14 of 21, by alpm
Sphere478 wrote on 2021-12-15, 06:28:
Totally true. Bought 3 (they only sell in triplets) for ~60 bucks in early January.
Reply 15 of 21, by marbury
Let's reopen a fairly old thread ... I too am looking for k6-2+ specifically and could get a 570 for "fairly" cheap from somebody...also the market seem devoid of 2+ as it is. The problem is that the 570 wants a 6x multiplier but my old SS7 board only supports up to a 5.5x multiplier. And the lowest voltage is 2.2v which I think wouldn't be a problem if the cooling can handle it?. I wonder what the implications are. Will this chip just run 10% slower then or will it not work at all? Will it explode? 😁
DOS Gaming: Biostar 8433UUD, AMD 5x86 P-75@150MHz, 64MB Ram, ViRGE 3D/DX 4MB, Aztech MM Pro 16ABI, Dos 6.22, Win 3.11
Windows gaming: Chaintech CT-5AGM2, AMD K6-2+/570ACZ@600MHz, 384MB Ram, Voodoo 3 AGP, SoundBlaster Vibra 16, Win 98
Reply 16 of 21, by Doornkaat
marbury wrote on 2023-01-26, 10:25:
The 2x multi setting for Pentiums is the 6x setting for K6-2/3(+) CPUs.😎
2.2V is ok with sufficient cooling.👍
Reply 17 of 21, by marbury
nice ... thanks. Ordered it 😀 ... it's "just"57Euros which others charging 75-120 Euros ... omg!
Reply 18 of 21, by dj_pirtu
Bought 3 of those k6-2+/570 from ebay and modded all of them to 3+ so 256KB cache. All worked fine.
Reply 19 of 21, by bloodem
dj_pirtu wrote on 2023-01-26, 10:52:
Same... I've now modded 7 of these, and 6 of them worked perfectly (I've had to revert the other one to a normal "2+", because the additional cache was faulty).
I've bought one last batch of K6-2+ 570ACZ CPUs a few months ago, and I'll keep these unmodified (hopefully I can resist 😁 ).
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
