First post, by red_avatar
OK this is driving me crazy. Here's the situation:
I have an IBM PC 330 from 1996 which I've upgraded from a Pentium 150 to a Pentium 233 MMX. The BIOS is IBM BIOS upgraded to the latest version (from 1999).
It originally had a 40GB hard drive installed that had 32GB accessible in Windows 98 SE. I replaced it with a 120GB SSD a few years ago but it would only recognize it as a 8GB drive. I forgot how but I recall being able to push up to 32GB as well but when I decided to use the PC last week with a new Voodoo2 card, it hard locked me on during driver installation and it would refuse to recognize the drive after this - I couldn't even repair the MBR.
What I did was just do a clean wipe and used FDISK to create a 8GB partition (the maximum it could make) with the intent to increase it in size using Partition Magic.
I've used Partition Magic with my Pentium III 800Mhz (also running Windows 98 SE) without any issues but I've now run into a snag. Here's what I tried:
- If I enlarge the partition, the PC refuses to boot completely - apparently this is common since it damages the MBR
- I then followed advice on this forum but Gparted boot ISO isn't bootable on this machine - I assume it's due to the ageing BIOS not accepting this type of BOOT CD (I've had this problem before with Linux boot CDs designed for 90's Pentiums)
- I then made a second partition, a logical one, sized 20GB (keeping the combined total under 32GB) and formatted it as FAT32
- When Windows 98 boots, it sees the partition just fine but can't write to it. If I then format it under Windows, it works fine. I can copy files to it, read the files, copy them back, etc.
- I tried the same but with a larger partition and yes, it works as well: I can even make a 100GB partition and format it and it will work under Windows.
- The problem starts when I enter DOS: when I attempt in any way to access the D drive, the PC locks up. DIR, CHKDSK, SCANDISK, FDISK, etc. they all cause DOS to freeze which is odd since DOS 7.1 is said to be able to handle drives up to 120GB
Does anyone have any idea how I can do either:
- enlarge the C drive while keeping it bootable
- create a D drive without DOS going crazy
- make C larger than 32GB without running into issues (I assume the 32GB partition in the past was that size for a reason - I just can't immediately find why - BIOS limitation?)
Thank you for any help!
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 16, by majestyk
Would a controller card (with it´s own BIOS) be an option?
Reply 2 of 16, by red_avatar
majestyk wrote on 2021-12-31, 16:30:
Well it worked before so I assume it would work again - I recall I probably used a bootable CD tool to do it with ...
But with controller card, you mean something like this?
https://www.bol.com/be/nl/p/via-vt6421a-pci-2 … lBoC4doQAvD_BwE
Retro game fanatic.
Reply 3 of 16, by majestyk
Did you use some additional software to address 32GB? There were tools abailable back in the days from Seagate or Maxtor to circumvent BIOS limitations.
https://www.deinmeister.de/e_over8mb.htm
For a controller it´s necessary that the used controller chip is supported by both WIN98SE and DOS - driverwise. Maybe an older controller from the 90ies wpuld be better here.
Reply 4 of 16, by red_avatar
majestyk wrote on 2021-12-31, 16:43:
I'll need to do some checking. I thought I found the CD I used - a Seagate Tool CD but it doesn't boot from it which is odd. Super FDISK is the only tool that wants to boot that I tested but this one is limited by the BIOS and hard locks when it detects the D drive.
Funny enough the D drive is fine in Windows - I can even access it within DOS running in Windows.
Retro game fanatic.
Reply 5 of 16, by red_avatar
OK I'm getting nowhere. I tried every hard drive tool I could find and none worked. EZ-Drive came the closest but a bug in the software meant that while having to enter the partition value, it refused to accept it because the maximum number was more than 5 digits. Plus, the EZ BIOS overlay caused a loooooong delay before booting which is unacceptable (like 20 seconds) and required extra steps to boot from disk or CD.
I don't get it - before I wiped the drive, I had a working 32GB partition. I think I originally formatted the drive on the PC itself to 32GB but can't find the right program. It's clear what needs to be done: I need to circumvent the Int 13h limitation of a 8GB drive which Windows 98 does just fine. I
know DOS relies on the BIOS for hard disk access so that explains why it freezes when I go over 8GB (since the BIOS doesn't support more thanks to Int 13h) but it worked in the past so I know something had been done to make DOS read more than 8GB, I just don't know what. There were also no boot up messages about an overlay used so either there was none, or it was not visible.
Does anyone have any more ideas? I've been at this for over 8 hours now and I'm really stumped. The BIOS also has the latest update.
Retro game fanatic.
Reply 6 of 16, by Plasma
If you have a NIC with an EPROM socket, you can install a Promise DriveMAX ROM which will add BIOS support for drives up to 128GB. I have done this in several of my computers.
Reply 7 of 16, by red_avatar
Plasma wrote on 2022-01-01, 11:49:
I've read about that. If I read right you don't even need to use the card - it will enable LBA support just by using your original IDE ports on your motherboard which is cool. It's a nice solution to keep in mind but I discovered my old post from 3 years ago where I apparently solved the problem myself without any help.
I didn't try it before because I thought it wouldn't work but if you make a partition of 32GB in Partition Magic formatted to FAT32 and then hook it up to the PC, BIOS will claim it's 8GB but FDISK actually sees it as 32GB which is peculiar because FDISK itself won't allow such a big partition by itself. Scandisk did throw up errors saying LBA is not enabled in BIOS but I'm letting it do a surface scan and hopefully after it's done, I'll still have a decently sized drive left.
Retro game fanatic.
Reply 8 of 16, by Sphere478
Re: Diy modding support for k6+And 120gb hard drives into bios roms
You may be able to use a xt-ide to get the drive working?🤔 (same concept as the network rom)
But yeah, a pci add in card is faster than any of these options. Personally, I use a 2.5” ssd and a promise tx4 sata II 300
Sphere's PCB projects.
Reply 9 of 16, by red_avatar
Sphere478 wrote on 2022-01-01, 13:30:
I still have a free PCI slot so I might just do that later on. You think it would support a BIOS that has no LBA?
Retro game fanatic.
Reply 10 of 16, by Sphere478
red_avatar wrote on 2022-01-01, 13:52:
Not sure🤔 if talking about network card and rom or xt-ide
Network cards and roms are cheap.
You may wanna invest in a chip programmer though. If you have one of those it’s just so easy to flash roms without having to jump through hoops pop it out, program it, pop it back in all from windows 10 machine. Super easy
But if talking about the promise tx4 yeah, should work no problem I have em on all my socket 7 builds
You could always see if chkcpu (jan) can patch your system bios he is in that thread.
If you do this right you should be able to use 120gb on the mainboard IDE
But with a tx4 I think you can use basically whatever you want. Even the latest 12tb drives.
But os and partition table limits apply there. Anything past 2 or is it 3tb and you have to use gpt or mbr and multiple partitions
Gpt requires windows vista/7 xp64 or server 2003 r2 if I recall correctly
I did once get gpt working on xp32 but it sucked
Not that you would be likely to use these drives, just info.
Any old 2.5” ssd will do.
Be sure to put your page file on a magnetic drive though. And disable prefetch, hard drive defragmentation, etc. stuff that writes the drive alot
Reply 11 of 16, by red_avatar
Sphere478 wrote on 2022-01-01, 14:27:
Not sure🤔 if talking about network card and rom or xt-ide […]
Thanks! I bought one for €25 including box & cables which seems a good deal. I wonder what the speed would be if directly connected to the card - probably pretty bad. However, it might be fast enough to hook up a SATA DVD drive?
Retro game fanatic.
Reply 12 of 16, by Sphere478
red_avatar wrote on 2022-01-01, 16:50:
What connected to the card?
Which thing did you buy?
Reply 13 of 16, by red_avatar
Sphere478 wrote on 2022-01-01, 18:02:
PROMISE SATA300 TX2plus / TX4
Retro game fanatic.
Reply 14 of 16, by Sphere478
red_avatar wrote on 2022-01-01, 19:38:
Sweet! I love mine.
It is sometimes picky about what slot it’s in. Try slot 1 or two first. 👍
I wanna say that I’ve seen 90 or so MB/sec on a modern pci slot/system. But some systems it is around 40 or so.
Reply 15 of 16, by red_avatar
Sphere478 wrote on 2022-01-02, 02:01:
Sweet! I love mine.
Hopefully I won't have to do a lot of shifting - I only have 3 PCI slots and the Voodoo2 is in the top one because of easy access. If it works I'll be very happy - now that I'm testing more and more games, I realize 8GB won't be enough for keeping even my favorite ones installed. Thinking back, my Pentium 166 had a 4GB drive very quickly and I still ran out of space so I had to get a CD writer to burn data to CDs and this was before I had the Internet so this was just my own files & games.
If I could get 120GB working it would be perfect - I'd be able to keep CD images of my main games to run by Alcohol 120%
Retro game fanatic.
Reply 16 of 16, by Sphere478
red_avatar wrote on 2022-01-02, 12:31:
Sweet! I love mine.
Use native sata drives the adapters cause problems often
