First post, by superfury
When I look at the PCI IDE controller in 'compatibility mode', it's supplying IRQ14 and/or IRQ15 to the interrupt controller (http://www.bswd.com/pciide.pdf).
But when I look at the PCI pinout, no IRQ14/15 pins exist? The ISA card does have those pins. Could it be that it usually uses an connected ISA card with just those two pins connected through a cable to supply the IRQs?
I never saw anything to support IRQ14/15 on PCI IDE cards?
UniPCemu Git repository
Reply 1 of 5, by LightStruk
As I understand it, PCI has four interrupt lanes, IRQA through IRQD. These four lines are shared by all PCI devices, and typically each PCI slot only has one IRQ line assigned to it to reduce contention for any individual PCI IRQ line. Integrated PCI peripherals on the motherboard or in the chipset also have to share these same lines. It's up to PCI interrupt routing, AKA the "Programmable Interrupt Router" ($PIR) table in the BIOS to assign an old-style, unshareable numbered interrupt to each PCI device via one of these four shared PCI IRQs.
That's how legacy software that only expects old-style ISA interrupts can talk to PCI devices. It's also how PCI devices can have interrupt numbers higher than 15 - it's just a number in a table, as opposed to a physical trace on the motherboard.
Reply 2 of 5, by Grzyb
superfury wrote on 2022-02-22, 11:40:
Such kludges did exist in early PCI era.
Later on, they got extinct - probably because motherboards already had two IDE channels, so no need for PCI cards using IRQ 14/15.
Reply 3 of 5, by Matth79
The TEKRAM DC290N PCI IDE included a paddleboard to connect into an ISA slot
Reply 4 of 5, by superfury
Matth79 wrote on 2022-02-22, 19:38:
Just took a look at it. I'd assume the paddleboard pretty much only connects the IRQ14 and IRQ15 from ISA lines to the IDE board, like you would think for easy IDE compatibility mode(PCI IDE ProgIf bits 0/2 being cleared to activate compatibility mode for Primary/Secondary IDE channel)?
Reply 5 of 5, by mkarcher
PCI IDE controllers that fully support compatibility mode either need the paddleboard like the tekram controllers, or are onboard components that have a connection to ISA IRQ14 / IRQ15. You are right that a standard PCI card can not confirm to that specification.
