The Tualatin 1.26 GHz CPU had a bunch of bent pins, so it took me a while to straighten them out. Put it in today, crossed my fingers, and it booted up. Ran some benchmarks to compare against the Nehemiah 1.2 GHz CPU.
A massive jump in performance, making it obvious that GF4 Ti4200 was being bottlenecked by the Nehemiah. The 3DMark2000 scores are unusually high.
Since I already have an Ezra-T based DOS PC, I have decided to stick with the Tualatin for this Win98 PC. The Nehemiah will remain a backup option if I want to add support for DOS.
The final configuration of this PC is below:
- Motherboard: QDI Legend Advance 10T ATX Socket370 [P6V694T/A10T]
- Chipset: VIA PRO133T / 694T [VT82C694T + VT82C686B]
- CPU: Intel Pentium III-S Tualitin 1.266GHz 512/133 [SL6BX]
- Cooler: StarTech FAN3701U Cooler w/ Copper Heatsink
- PSU: Seasonic 350W ATX12V 80 PLUS [SS-350ET]
- RAM: 512MB PC133 133 MHz SDRAM
- Video: MSI MS-8894 NVIDIA GeForce 4 Ti 4200 64MB AGP [Ti4200-VTD8X]
- Video: 3DFX Voodoo 3 3000 16MB PCI
- Audio: Sound Blaster Audigy 1 PCI [SB0090]
- MIDI: Roland SoundCanvas SC-50
- FDD: NEC FD1231M 3.5" 1.44 MB
- CD/DVD: NEC ND-1100A DVD-RW 4x
- HDD: SD to IDE Adapter + 64GB MicroSD + Custom 3D printed floppy drive bay from some guy on eBay
- USB: USB 2.0 w/ HD Audio 3.5mm Floppy Bay Front Panel + 3.5-Inch to 5.25-Inch Front Bay Converter
- ZIP: Iomega Zip 250
- Case: HEC 7106BB
- Monitor: DELL 2007FP LCD
- Keyboard: Logitech Y-BE22
- Mouse: Logitech M-BE58
- Joy: Gravis Gamepad
- Joy: Saitek P880 Gamepad
