Help with Super C
Reply 20 of 24, by wd
Rank DOSBox Author
DOSBox Author
Well maybe you have docs of that program and can see what graphics
cards it actually supports.
Reply 21 of 24, by mf2hd
I've found in a bbs mirror an "infinity machine", it is a tsr and seems a cheats collection.
Is it the one in attachment ?
If it's that one,there is not a file that explains how to use it but it seems running in vga only.
The command line help (redirected to a txt) shows:
Infinty Machine: The Universal Gamecheater - Version 1.5 ( 03/05/95 )
(c) Copyright 1993-94 REM Software, All Rights Reserved. Commercial Version.
Usage: INFINITY [options]
/s:method Specify swap method. ( method = XMS, EMS or FILE )
/u Remove Infinity Machine from memory.
/x Enable alternative keyboard activation for DOS extendors.
/timer Enable alternative timer routine.
/? Command line help.
Reply 22 of 24, by mgman
Yeah, that's the one. And there were no docs in my folder either on how to use it.
Reply 23 of 24, by mf2hd
It's a "terminate and stay resident" program and there are two hot-key mode for the "call up" :
"Print" key if it was started as "infinity" and "dubble press the left shift" if it was started as "infinity /x".
The first one doesn't works on my keyboard, the 2nd one shows errors in status window (see attachment).
Reply 24 of 24, by mgman
I've tried some methods, though none of them work.
