First post, by tomcattech
- Member
The good:
A Ti 4200 w/128 MB and 8x AGP. (I thought they were all 64?) I'm willing to bet the clock speeds are tweaked out of the box as well.
When it works, this thing is awesome and puts up some great stats in 3dMark 2001 SE.
The bad:
When it doesn't work, it will not get through all the tests in 3D mark and hang the entire system.
When it doesn't work, just about every game will hang, forcing a total shut down\reboot.
I've pretty much troubleshot drivers out of the equation and receive similar issues on different Win98 units with different motherboards, chipsets, etc....
I'm pretty sure we've got a hardware issue here and not heat generated.
Caps look good, nothing singed\burnt.... etching on the board is in good shape.
I'm leaning toward some memory starting to give up the ghost.
Any other ideas?
