First post, by appiah4
Matrox's Driver site lists G450 drivers for Win 3.1 as "none planned": https://www.matrox.com/graphics/en/support/dr … atest/previous/
However, there is a Win3.1 driver for G400: http://www.matrox.com/graphics/en/support/dri … es/w31x_161.php
Considering the two cards use essentially the same chip with very slight improvements and a 64-bit memory bus, and considering they pretty much share the same driver package for all legacy OSs, I was wondering whether this driver worked for the G450.
Has anyone tried this and can confirm?
Reply 1 of 10, by Rawit
appiah4 wrote:
Matrox's Driver site lists G450 drivers for Win 3.1 as "none planned": https://www.matrox.com/graphics/en/support/dr … atest/pre […]
I remember reading here on Vogons that it doesn't work. I thought it was unfortunate at the time, as the G450 is easier to find than a G200 in PCI.
YouTube
Reply 2 of 10, by appiah4
Aww schucks, that's quite the bummer.. I suppose I'll have to make do with the generic SVGA driver 🙁 It's amazing that I can find an OS/2 Warp driver for a card from Matrox but no Win3.1 driver. I didn't even think to check, automatically assumed it would be available.
Reply 3 of 10, by Rawit
If you have the card you can always try it. I wonder myself why it doesn't work. I did notice that the Matrox BIOS update packs are the same, they group 200/400 together, but the G450 uses different files. So I guess the chips do differ more than we think.
YouTube
Reply 4 of 10, by Errius
There's a similar issue with using the G550 in Windows NT 4.0. No driver exists although it would have been trivial to produce one.
Is this too much voodoo?
Reply 5 of 10, by NJRoadfan
If you ever get a chance to run it, The Matrox G400 driver for Windows 3.1x is one of the best out there. On-the-fly resolution and color depth switching via PowerDesk and it has full DCI video acceleration.
Reply 6 of 10, by dr.zeissler
That's interesting. Thought the G450 is a capped G400-chip but I did not have tested the win3x-driver on my g450 agp yet.
If this will be true that it's not working, then I will skip dos/win3x on that setup but I will go for OS/2, WIN9X, WIN2K, Linux, Amithlon.
Reply 7 of 10, by appiah4
OS/2 is a better DOS than DOS anyway. 😁
Reply 8 of 10, by dr.zeissler
Beside that, the G450 is a really good card. I like the image quality. I have ordered the G550 too.
Would be interesting how they compare in terms of driver-support, featureset, performance. image quality should be top notch so no complains here.
Reply 9 of 10, by Disruptor
I got a G450 PCI running in a 486 after several BIOS patches by mkarcher.
Matrox G450 (with DVI outout) working on a HOT433 main board (UMC 8881)
It is not yet stable at 40 MHz FSB, but I will try to find a cooler for the AGP/PCI bridge chip.
Who else has a working DVI port on in a 486 computer?
Reply 10 of 10, by dr.zeissler
I try to avoid DVI where possible because in some cirmustances I need 720x400@70hz for smooth scrolling in dos.
