First post, by oblivious
I've been at it all day trying to get dosbox running so I can play Dark Sun. NOTE: THE PROBLEM IS NOT WITH DARKSUN, BUT WITH DOSBOX
When I ran dosbox .70 I got this in the status window:
"Config: loading primary settings from config file dosbox.conf"
And then I got the standard XP "encountered a problem" error message and it crashes.
Nothing I've done has gotten dosbox to work. I loaded .65 and .63 and they work, but they won't run Dark Sun. Every time I try to run Dark Sun it immediately crashes back to the dosbox command line and I get an "Illegal command: mode" message. I don't know if this is a problem with the dosboxes or with Dark Sun.
I'm sorry if i'm being just another annoying noob with a regular problem, or if I missed something obvious, but I've been looking all day and I can't find anything that addresses this.
HELP! :_(
PS:
The Dark Sun intro works perfectly fine when I run it without Dosbox, but it dies at the end of the intro and tells me I don't have enough ram. I've got 2gigs, so I doubt it.
