First post, by doaks80
No setup or install script (or config file) to select sound device...is there a way? Original non-CD VGA versions in DOSBOX currently.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Reply 1 of 5, by lightmaster
Gog or Steam version?
Reply 2 of 5, by doaks80
Floppy versions.
Reply 3 of 5, by CrossBow777
The original floppy games basically defaulted to adlib sound or PC speaker if adlib couldn't be found. To force to something else like roland, required a patch file for the original monkey Island 1 but once in place, you would initiate roland sound by using the -r switch after the executable.
So..
monkey -r -v
I believe should load up monkey island 1 with VGA graphics (Assuming you have the VGA version) and roland sound for MT-32.
Monkey island 2 is similar if I've not mistaken?
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 4 of 5, by doaks80
CrossBow777 wrote:
The original floppy games basically defaulted to adlib sound or PC speaker if adlib couldn't be found. To force to something els […]
So..
monkey -r -v
Thanks brother...just tried it out on my external CM-32L and it sounds great. Although the command in just "monkey r v" without the "-" 😀
Reply 5 of 5, by NovaCoder
Cool, just starting playing this on my MiSTer FPGA computer with an MT-32 pi 😀
