Red Baron 3D
First post, by Boelcke jr.
Hello there!
I have a question about OpenGlide & Red Baron 3D:
It works quite fine in flight, the only minor bug is following:
In the Menu Screens, the Animations are gone, also the Decoration-Animations are blank! In flight, the Mouse-Cursor makes the game really slow & the Cursor is a box ...
But after all, in flight it works really fine! Great job done!
Any solutions?
Reply 1 of 5, by GoldFinger
What version of OpenGLide are you using? what is your video board? Are you using any patch in RedBaron 3D?
Reply 2 of 5, by Snover
Hm.. I wonder if Microsoft, in competing with open-source APIs, did something nasty in DX9 to cripple OpenGL games. (Or it's just extremely buggy. 😉) I've just seen DX9 causing a lot of problems with various things.
Yes, it’s my fault.
Reply 3 of 5, by Glidos
You might try asking about this in a Red Baron forum. It might be that these are also missing when you use a proper voodoo card, because the Glide version didn't support it.
Reply 4 of 5, by Boelcke Jun.
Hello again!
I'm using OpenGlide 007b & 009RC3, both versions caused the minor problems as described above! Im using Rb3D with CM11 & new planes & the TW-Terrains & PL-Sound & object Pack!
Thanks for Replying!
Reply 5 of 5, by Nicht Sehr Gut
Originally posted by Boelcke Jun. Im using Rb3D with CM11 & new planes & the TW-Terrains & PL-Sound & object Pack!
I think you're going to need assistance from some of the ultra-dedicated Red Baron fans on this. Whenever you add-on un-official objects, textures, etc... it can have a profound effect on the way Red Baron performs with the OpenGlide DLL.
Do a quick search at the top of the page using "Red Baron" and scan the older posts back when the initial Red Baron flood cam roaring through here...
