First post, by xpan
Hi, I'm using v2.78.2 for this game, and here is what I got:
657.15 KiB
Reply 2 of 4, by xpan
Thanks for the reply! The dgVoodoo settings are the default, except VRAM is set to 4096MB. The game is set to 2160p Fullscreen High Quality. I also tried 1080p and Windowed mode and the problem is the same.
The PC specs: Windows 11 Pro 21H2, 3080Ti with v512.59 driver, i5 11400F, DDR4 8GB*2, Z490 chipset.
Cheers
Reply 3 of 4, by Truth Unknown
I have the same problem, the last version that seems to work is 2.77. Unfortunately if I use that version, I sometimes (seems stage dependent) get texture corruption or something on reflective surfaces, but I'm guessing that's been fixed based on the current version despite the skewed view.
