First post, by dickey
Dosbox 0.70 constantly crashes whenever I set "core=dynamic" in dosbox.conf, and it shows the following error message:
"Exit to error: Ran out of CacheBlocks"
I tried change cycles to different values (max, 5000, auto), but it doesn't solve the problem. Change the core setting into "auto" or "normal" makes dosbox more stable though.
I'm running Dosbox 0.70 in Ubuntu 7.04 on a Thinkpad T60 (Intel Core Duo T2500).
Any suggestions? 😁
Opteron 165 0550UPMW 300x9=2700Mhz (vcore=AUTO in BIOS)
DFI NF4 UT Ultra-D (6/23/2005)
PQI Turbo 3200-2048DB @207Mhz(7/10) 3-3-3-6
Antec TP-II 550w PSU
VisionTek X800 128MB @440/420
Cooler Master AMMO 533
Windows XP pro SP2
