First post, by NarakuITA
Hi I need an expert help.
I have an IBM 330 6577 - 59T with Microsoft Windows 95 C OSR 2.5.
I am trying to install ActiveSync 3.1 but the installation fails giving me the following error:
The TCP / IP Protocol must be installed on this computer before Mirosoft ActiveSync can be installed.
Click ok quit Setup. Then, open Control Panel, double-click Network, and install this protocol.
Now, I state that I don't have a network card, and I manually installed: Existing Ndis2 Driver (even if Windows tells me that this card has been detected together with another existing ODI Driver), so in NETWORK I have installed the TCP / IP protocol .
I restarted the PC, but apparently the problem persists. Isn't it that you need a real network card? Or is there something else to do? Thank you so much I await answers!
Reply 1 of 1, by NarakuITA
Having already solved the problem alone. I have a Question, of curiosity. Is there a ActiveSync for Microsoft Windows Workgroups 3.11? To synchronize Handheld PCs?
