Reply 20 of 29, by Jackhead
Build in some LEDs anything runs like a charm.. Installed win98SE .
im really impressed how good the voodoo5500 runs dos 6.22 and win98SE. I pulled the card out of another system (Pentium3 /win98SE/ Asus p2B) and i tryed to replaces the voodoo with a 9800pro or a geforce 2MX. But any of this cards i got irq problems... The P5A runs old games like Wizardry6 or M&M3 till M&M 8 with 3dfx perfect. The k6 III+ 600MHz push the 1999-2000 Games to run perfect and i can go back to dos with disable cache to enjoy midi DOS.
I use alot of external MIDI on the Roland MPU-401AT (the XV-5080 is the best on GM midi):
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 21 of 29, by lolo799
Now if all those leds could be used as blinkenlights instead of an ambient lighting...nice colour though, perfect for Subwar 2050 or Archimedean Dynasty!
What are the 3 vertical computers on the left?
Reply 22 of 29, by Jackhead
Since i used the system only for DOS6.22 i switched the GPU. Im still testing what works best for me. At the moment i added a PowerVR Matrox m3d PCX2 with a ATI rage 128 PRO.
Will also test a Matrox G250 and G450 soon.
Maybe also add a voodoo1, but im not sure i run than in IRQ conflicts 😀
1.57 MiB
Never posted picture of this baby, i musst say i really love this roland board. The MPU-401 AT. I think the best midi interface you can get for DOS Gaming.
No need for breakout box, no hanging note bug, you can add a wavetable board and get the audio direct with rca or phone jack.
Never get me any problem running any midi device.
1.94 MiB
Also add a OPL2LPT V2:
1.69 MiB
Reply 23 of 29, by Jura Tastatura
I like your rig and also like mixing old and new as long as it maintains compatibility. Regarding that Roland card, just got yesterday Keropi's version of it (ie. Music Quest clone) and installed it to my pimped DOS rig similar to yours. 😁
Reply 24 of 29, by Jackhead
I did some upgrades. The MPU-401AT got a Yucatan FX , GPU switched to a Matrox G400 MAX with the Matrox PCX2
1.96 MiB
356.13 KiB
Reply 25 of 29, by Joseph_Joestar
Jackhead wrote on 2022-06-25, 15:12:
Great card! I was just doing some tests on my own Matrox G400 and I'm still amazed by its image quality.
Running it on an LCD monitor at 1280x1024 over a VGA connection at 60 Hz, and the image is razor sharp. I don't know of any other card from 1999 that can produce such picture clarity at that resolution.
Reply 26 of 29, by Jackhead
Yes i had a voodoo 3 3000 before, but the vga quality of the g400 max is reference.
Even its overdose in my system, because i run most time dos6.22.
Its really good for the last DOS stuff like Cybermage, Tomb Raider, Decent to Undermountain ..
Reply 27 of 29, by Jackhead
I spend the G400 MAX a new fan, old one getting really loud..
1.42 MiB
I also switched from the SCSI2SD to a IDE -> mSata Adapter with UDMA2 support and a 32GB MLC mSata.
Here a DOS Bench with AMD K6 III+ 450 @ 600MHz 2.2V
1.06 MiB
Reply 28 of 29, by H3nrik V!
Jackhead wrote on 2022-12-19, 17:11:
I spend the G400 MAX a new fan, old one getting really loud.. […]
And an M3D? With heat sinks on the memory? I like!
Reply 29 of 29, by Jackhead
yes i tryed first as it comes, but after short time the pcx2 and rams got really hot without cooling. So i think worth give it some cooling for longer life , hopefully 😀
