First post, by FeedingDragon
Ran into a problem when I imaged and tried to install these 2 games.
It seems the packaged installer for Future Magic uses wildcard patterns that DOSBox doesn't suport. One work around is to install with a DOS 6.22 (or equivelent) boot, then copy the files over. But I found it easier (for future installs,) just to re-write (didn't take much work,) the 2 guilty bath files. They accomplish the same thing, but now are a little more streamlined, and don't use the illegal wildcard patterns 😀 Just unpack and insert them into the Disk-1 image.
Hard Nova installes just fine, but the startup batch file, again, uses illegal wildcards. Didn't do much streamlining this time, but I did remove the illegal wildcards. Just replace the batch file in your install directory after you've installed the game.
FM-BATCH.7z
HN-BATCH.7z
Feeding Dragon
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Renaming with wildcards, including that done with COPY commands, can be problematic. FYI, you can load an alternate shell, such as COMMAND.COM from MS-DOS or 4DOS, to get more full-featured commands, and can still use local drive mounts. SVN has fixes that help COMMAND.COM from MS-DOS to work better, if you want to use that shell. If you try to load the shell from MS-DOS 6.22 you will first need to do a "VER SET 6 22" command to change the reported version of DOS or the shell won't load.
