First post, by Scirocco
Hi. I have Sapphire Radeon HD3650 AGP versions. I am looking for drivers for this card under Windows 98. Have any of you used this card under this system?
Reply 1 of 12, by paradigital
Pretty sure there are no Radeon drivers for cards beyond the X850 for Win9x.
Reply 2 of 12, by Scirocco
There are no reference drivers for sure. And OMEGA drivers? Or maybe the drivers for WinME or XP will work on W9SE?
Reply 3 of 12, by The Serpent Rider
No drivers means no drivers exist. But you're free to try backporting Linux opensource AMD drivers to Win9x. Have fun.
Reply 4 of 12, by paradigital
Scirocco wrote on 2022-05-29, 18:10:
WinME drivers also don’t exist AFAIK, as they are typically the same bundle as Win9x.
WinXP drivers won’t work on 9x as the driver architecture is completely different.
Reply 5 of 12, by Socket3
The Serpent Rider wrote on 2022-05-29, 18:20:
that would be awesome if possible...
Reply 6 of 12, by Rikintosh
I think a radeon 3850 on win9x is unnecessary. You wouldn't get any benefit from this card. It's like using a Porsche to help a little candle cross the street (with the old lady outside the car) In my opinion you should have a GF4 Ti or something
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 7 of 12, by cyclone3d
Socket3 wrote on 2022-05-30, 17:24:
Should be possible but would be a ton of work. A lot of absent functions would probably have to be written from scratch.
Guessing that the Linux code would basically be a strating point to see how stuff worked.
As someone who used to try to keep a version of a program able to be cross compiled for Windows and Linux, I dropped the Linux part when I rewrote a large part of the program and because it took so much extra work to make it work for both Windows and Linux, I dropped the Linux compatibility.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 12, by darry
The last ATI cards supported under Windows 98 are the Radeon x300/x600/x700/x800/x850 (and their AGP equivalents) using Catalyst 6.2 . The 3600 series is 3 generations newer .
Backporting Linux opensource AMD drivers to Win9x is certainly not impossible, but there is little likelihood that someone would commit the considerable time and energy required to complete such an endeavour when there are multiple other cards available that have working Windows 9x drivers already.
Reply 9 of 12, by cyclone3d
If I had time, I would do it. What's a little rebuilding a whole driver from the ground up?
Not like I haven't been given horrid messes of programs before that I rewrote from scratch. No, I'm not bitter at all about any of those. Not one bit.
YMF7x4 Guide
Reply 10 of 12, by Socket3
cyclone3d wrote on 2022-05-31, 04:34:
Well if you ever pull it off, free beer from me, and others I'm sure!
Reply 11 of 12, by swaaye
Are you sure you'd want a Radeon HD for Win9x? The DirectX 10 cards have some significant backward compatibility issues.
Reply 12 of 12, by agent_x007
I would focus on X1000 series instead of HD 2xxx/3xxx, and called it a day.
