Reply 20 of 29, by Intel486dx33
More photos
Reply 21 of 29, by Intel486dx33
Even more photos
Reply 23 of 29, by rasz_pl
kitten.may.cry wrote on 2022-06-07, 13:36:
I'd love to cast my own high purity copper cooler.
did you mean skive? https://www.youtube.com/watch?v=E72Pr3O9IoY
obligatory family guy https://www.youtube.com/watch?v=518F4JoO3dg
Reply 24 of 29, by kitten.may.cry
rasz_pl wrote on 2022-06-07, 15:13:
No, not as sophisticated.
Reply 25 of 29, by pentiumspeed
What I did with HP Z420 was upgrade the heatsink it had, using Z440's heatsink. One more heat pipe and better design netted me about 15 to 20C cooler on a 8 core CPU, play and plug.
Cheers,
Great Northern aka Canada.
Reply 26 of 29, by Intel486dx33
pentiumspeed wrote on 2022-06-08, 00:24:
Cheers,
I have a couple HP z420 I want to fix. The motherboards went bad. I think they have 8-core xeons.
Reply 27 of 29, by RetroPC_King
This is my rare Foxconn Socket 462 CPU cooler. It have aluminium frame and copper base and fins. It is used on my ASUS A7N8X-E Deluxe with AMD Athlon XP 2500+ CPU.
    41.91 KiB
    847.85 KiB
Reply 28 of 29, by pentiumspeed
Intel486dx33 wrote on 2022-06-08, 03:07:
Cheers,
Plenty of Z420 motherboards on ebay but first, reset your CMOS by unplug power cord and press & hold the button on the motherboard for at least 15 seconds. This sometimes brings out of retard mode.
Second, you can use unbuffered ECC from 4GB or 8GB per stick and also motherboard supports buffered ECC memory up to 128GB within reasonable price again, from ebay.
Cheers,
Reply 29 of 29, by mastergamma12
I suppose my cooling solution on my Pentium 3 system would count
file.php?mode=view&id=96716
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
