GOG Redguard Performance
Reply 40 of 60, by robertmo
Opaque79 wrote on 2022-06-15, 20:12:
robertmo wrote on 2022-06-15, 18:49:
my second link has only one exe and one bat
Only helpful with a physical copy, not with the GOG version
The entire disc2 is mounted as an image, and it's in the cue/bin format for redbook audio support (Rename game.gog to game.bin and game.ins to game.cue, and you should be able to see the files)
and mount that (.cue) in daemon tools light
Reply 41 of 60, by Opaque79
Still no dice. CUE image not found
Reply 42 of 60, by liqmat
Opaque79 wrote on 2022-06-15, 23:57:
game.ins = cue file
game.gog = bin file
I would copy them and rename.
Don't forget to edit the cue file so it points to the right bin file which would be whatever you rename it.
Reply 43 of 60, by Opaque79
Still didn't work. I don't want to try anymore. Thanks anyway for trying
Reply 44 of 60, by robertmo
you can also try to mount just the .bin in daemon tools light
if that still doesn't help you can just mount the hdd image in daemon tools light and just copy the .smk files to the hdd image
and edit system.ini
[system]
animation_drive=c:\
Reply 45 of 60, by Opaque79
robertmo wrote on 2022-06-16, 00:37:
you can also try to mount just the .bin in daemon tools light […]
and edit system.ini
[system]
animation_drive=c:\
I did try that but got the same error. No worries though, using DGVoodoo and the tweaks you posted, I guess 15-20 fps isn't too bad considering the game's age (as well as AMD CPU).
Would removing the fog cause more or less drops?
Reply 46 of 60, by robertmo
increasing view distance needs more power
Reply 47 of 60, by Opaque79
robertmo wrote on 2022-06-16, 00:55:
We've got somewhere. Lowering the draw distance has boosted the FPS
Reply 48 of 60, by robertmo
if you wonder what's there on the horizon in highest distance view (all 6 teleports on one picture + a soldier (over right redguard's arm 😉 ) (no idea why that one is so important 😉 )
Reply 49 of 60, by Opaque79
In any case, I've got a smoother frame rate by halving the draw distance despite this drawback
https://i.imgur.com/IW2Nkv9.png
Not a major issue though
Reply 50 of 60, by robertmo
Opaque79 wrote on 2022-06-16, 00:41:
just mount the hdd image in daemon tools light and just copy the .smk files to the hdd image and edit system.ini [system] anima […]
and edit system.ini
[system]
animation_drive=c:\
you cannot have same error when mounting hdd image in daemon tools lite.
cd is not needed at all (you just won't have music)
Reply 51 of 60, by robertmo
you should be able to copy all files from the CD under dosbox
just quit the game from the menu and stay in dosbox
if dosbox automatically quits, than edit dosbox.conf at the end by removing the quit option (or the quit from bat)
anyway the movies are not needed too to just start the game for testing 😉
even tha speech file is not needed 😉
you can just copy the gog files to hdd image and it should be enough
you can add all that extra staff one by one later once you have the game running
Reply 52 of 60, by Opaque79
Doesn't matter anyway, got tired of trying it and I've got it playable now
Reply 54 of 60, by Opaque79
May I ask what that's about?
Reply 55 of 60, by robertmo
liqmat wrote on 2022-06-15, 21:29:
robertmo wrote on 2022-06-15, 19:56:
Redguard distant sound loud
liqmat i wonder if you confirm the bug
Yep. Snake charmer is loud when I walk away from him, but fades in appropriately as I approach him. Weird thing is, that snake charm tune plays in several parts of the city (snake charmer not present) and those fade in/out appropriately with distance. It's like once the sound file is going full volume it wont stop until the sound effect is complete and then just cuts off.
Re: Redguard distant sound loud
Reply 57 of 60, by robertmo
liqmat
what would be interesting to check as you got 31 fps in dosbox:
1. to get more fps go from the ship in the harbor through the left gate and to the beach and look at the see, (make a save cause navigating after the next step is a bit different if you don't remeber the map 😉 )
2. lower view distance as much as you can (to get even more fps):
SYSTEM.INI
[xngine]
back_plane=300
(you should have a nice over 100fps now (run game and check 😉 )
3. now you set a 12 fps limit in dgvoodoo2,
and check how the game behaves this way.
Whether it behaves normally or is it in slow motion
i think the game will start too fast, in a seconds slow down to normal, and question is whether it will slow down in seconds second time to slow motion
(sound doesn't matter, just notice whether the sound quality got worse or not)
i already know how to handle the slow motion with preserving high fps in qemu properly but just wonder if dosbox gonna have same effect and if it is a problem of qemu or the game
(this has nothing to do with sound bug)
(this has nothing to do with my previous post) (the long one in other topic 😉 )
Reply 58 of 60, by Opaque79
Tried the Steam version of Redguard. As it's the software version, it runs a lot better for me
Reply 59 of 60, by liqmat
robertmo wrote on 2022-06-17, 06:46:
SYSTEM.INI [xngine] back_plane=300 (you should have a nice over 100fps now (run game and check ;) ) […]
SYSTEM.INI
[xngine]
back_plane=300
Not quite 100fps, but with the back_plane set at 300 I got to see a hell of an air show!
