DOS game programming
Reply 21 of 33, by Peter Swinkels
@procyon:
I remember that scene! 😀 But what is the point of linking to it in this thread?
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 22 of 33, by Procyon
Peter Swinkels wrote on 2021-09-10, 20:21:
@procyon:
Just as a reminder that it's pretty old stuff your dealing with. 😁
And I love that scene and use any excuse to post it. 😜
Reply 23 of 33, by Peter Swinkels
Yes, this thread is old I admitted I was aware of that earlier. And anything DOS related is 20+ years old in most cases. Isn’t that the point of this whole website?
Reply 24 of 33, by yevrowl
Is it possible to determine the graphics adapter using Q(uick)Basic, at least for compatibility with CGA-EGA-VGA?
Reply 25 of 33, by pan069
You can use Int 10h function 1Ah to get "Display Combination"
In this document at the bottom of page 21: http://www2.ift.ulaval.ca/~marchand/ift17583/dosints.pdf
If you call Int 10h/1Ah then BL will contain the "active display code".
See here for more information on how to call interrupts in QuickBasic (QBasic doesn't support this): http://www.petesqbsite.com/sections/tutorials … interrupts.html
Reply 26 of 33, by Peter Swinkels
@pano69:
QBasic doesn't support CALL INTERRUPT but it does support CALL ABSOLUTE. I've never done it myself, but it should be possible to write a machine language procedure to call interrupts using that statement.
Reply 27 of 33, by pan069
Peter Swinkels wrote on 2022-06-28, 21:54:
@pano69:
Ah, okay. I'm not that familier with QBasic to be honest. But having said that, I haven't touch QuickBasic in any meaningful way either for the past 25 or so years 😀
I guess if people are hellbent on getting interrupts to work in QBasic then the CALL ABSOLUTE could work (like yourself, I never used it) but I guess when you come to a point like that it might be useful to ask yourself if QBasic is actually the way forward.
But then again, I guess the masochism of using old computer systems is part of the charm. 😀
Reply 28 of 33, by Peter Swinkels
Perhaps the op should consider using C or C++. Or even Turbo Pascal.
Reply 29 of 33, by yevrowl
Peter Swinkels wrote on 2022-06-29, 10:20:
Helped at the cyberforum:
ON ERROR GOTO etrap
er = 0
SCREEN 12: SCREEN 0
ON ERROR GOTO 0
IF er = 0 THEN a$ = "VGA": GOTO pr
ON ERROR GOTO etrap
er = 0
SCREEN 9: SCREEN 0
ON ERROR GOTO 0
IF er = 0 THEN a$ = "EGA": GOTO pr
ON ERROR GOTO etrap
er = 0
SCREEN 2: SCREEN 0
ON ERROR GOTO 0
IF er = 0 THEN a$ = "CGA": GOTO pr
a$ = "Unknown"
pr:
PRINT "Video adapter is "; a$
END
etrap:
er = ERR
RESUME NEXT
Reply 30 of 33, by Peter Swinkels
This could be adapted to other languages as well:
https://www.phatcode.net/articles.php?id=210
EMS for QuickBASIC
Reply 31 of 33, by yevrowl
For CGA emulation in Hercules there is HGCIBM.
Is there a solution to emulate EGA in Tandy (PCJr)?
Because the video modes are similar (320 × 200 × 16) — https://groups.google.com/g/comp.sys.tandy/c/qQ7XYKSLItA
And also, perhaps, similar solutions for Olivetti and Plantronics Colorplus?
Reply 33 of 33, by Marco
Do you know further games besides Tyrian and crusade (what I read here) that use 16BIT extender?
1) VLSI SCAMP 311 | 386SX25@30 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | SG NX Pro 16 | LAPC-I
