Is this Cache?
First post, by Iris030380
Hi guys,
I found some cache on a stick. Not sure how much cache is on there though.
Anyone know what it is?
Written on it are :
IDT 7MPV6203A REV00
And also : 64KX 64SRAM
IDT 702
11540H8146ZJ111772D2DB
It's double sided, and on each of the 4 chips, it says :
IDT
71V432
S7PF
Z9652P
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 1 of 20, by DerBaum
It should be a 512kb (Kilobyte) Module. 32x32kbit (per chip) x4 (chips) / 8 (a byte are 8 Bits) .
If my math is wrong please let me know how to calculate it right.
Datasheet for the chips: https://www.renesas.com/us/en/document/dst/71 … uage=en&r=13441
FCKGW-RHQQ2
Reply 2 of 20, by pancakepuppy
DerBaum wrote on 2022-07-22, 18:53:
Your math is right on. There's a datasheet for an older revision of this cache stick series from IDT and it specifies the IDT7MPV6203 to be a 512KB Pipelined Burst module for Intel 82430 Family Core Logic PCISets (probably FX/HX/VX? I still haven't been able to figure out the particulars of COAST versions.)
Reply 4 of 20, by TrashPanda
Ok now this might be left field but it well has to do with the question asked.
These cache chips on this tiny mini board . .am I right in thinking they are in fact the wonderful fake cache ICs ?
I also have no idea what this board actually is other than it was made by HTE in December 1995, if anyone has an idea and wants to share it that would be great.
I was considering getting this board due to its compact size and that lovely looking TI 486 DX 100, its smaller than a baby AT board and the lack of VLB doesnt bother me since it has PCI.
Reply 5 of 20, by The Serpent Rider
That's PCCHIPS board, so of course it's fake cache.
Reply 7 of 20, by The Serpent Rider
PCCHIPS were sold under different brands, but all can be easily identified by revision number ("Vx.x") near a keyboard connector.
Reply 8 of 20, by TrashPanda
The Serpent Rider wrote on 2022-07-22, 22:11:
Thanks for that, now I know what I need to look for !
Shame about that board its a compact little number.
Reply 9 of 20, by DerBaum
TrashPanda wrote on 2022-07-22, 22:04:
Google gives exactly 0 results when searching for "16c328ah" ... Thats not a good sign.
And the "WRITE BACK" makes it look even more fake. It feels like "Hey look at these chips... its totally Cache and no fake stuff! Trust the text!"
I would put them in my collection. I like the weird stuff.
Changing the chips for real ones shouldnt be impossible... (If the board even works with real cache)
FCKGW-RHQQ2
Reply 10 of 20, by TrashPanda
DerBaum wrote on 2022-07-22, 22:33:
Google gives exactly 0 results when searching for "16c328ah" ... Thats not a good sign. And the "WRITE BACK" makes it look even […]
I couldn't identify a PCCHIPS board till this thread but even I know that no replacing the chips will do exactly zip, not only did they put fake chips on the board they are not even connected via traces to the CPU on teh vast majority of the boards I have heard stories about. But I now know to look for the VX XX marking and will in future avoid these boards, as for adding it to my collection .. if it was considerably cheaper than it is .. I might just because I too have a thing for odd hardware and it should be a right of passage for every collector to have at least one PCCHIPS board.
Instead I have a possible replacement in a ZIDA mini board based on a SIS chip set ..dunno yet as it honestly doesnt strike me as a good looking board.
-Christ my spelling sucks after a 12 hour shift.
Reply 11 of 20, by DerBaum
TrashPanda wrote on 2022-07-22, 22:42:
...but even I know that no replacing the chips will do exactly zip, not only did they put fake chips on the board they are not even connected via traces to the CPU on teh vast majority of the boards I have heard stories about.
I thought to see traces between the chips on the first picture. this is why i mentioned a swap.
It also looks like it was prepared for even larger cache chips (4 unconnected holes above the chips).
But i have exactly zero experience with pcchips boards.
FCKGW-RHQQ2
Reply 12 of 20, by Iris030380
SHOCKING I have zero notifications have to do the hard workmyself of returning to the this SHEER TUMROIL of off piste discussion! BUT AT LEAST I know now, that I have 512KB COAST. With a IDT brand on it. USELESS that it is to me, entirely. But it looks cool!
Maybe I'll keep it. But if someone needs it, they can have it. Cos I certainly got no use for it.
Reply 13 of 20, by TrashPanda
Off post .. a question was asked, you got an answer to yours and since the question also applies to my situation I simply used this thread rather than start a new one asking the exact same question.
This is how forums work and I believe the mods do prefer to keep similar questions to the same thread rather than making multiple ones.
Reply 14 of 20, by Iris030380
So does anyone require it? Be a shame to throw it back in the box. Might be useful to someone.
Reply 15 of 20, by TrashPanda
Iris030380 wrote on 2022-07-22, 23:17:
Just a thought but Coast modules can be hard to come across especially 512k ones and since you have that one it might be worth holding on to it should you ever acquire a motherboard that can use Coast modules.
I mean if you are never going to use it then im sure someone here may be interested.
Reply 16 of 20, by Errius
That's a PCChips M921. I have one as the basis of a DX2-66 build. I like it a lot even with its derpy fake cache. With 8 MB RAM, it's too slow for Windows 95C, but is a great little DOS machine. It's the only machine I have that runs Dune II without audio problems.
Is this too much voodoo?
Reply 17 of 20, by The Serpent Rider
Zida 4DPS is practically LuckyStar LS-486E clone, with minor slot difference, which has good documentation and one of the top boards for overclocking.
Reply 18 of 20, by TrashPanda
The Serpent Rider wrote on 2022-07-23, 08:38:
Might be worth taking a second look at, wonder how it would go with a Am5x86-133 in it, pretty much a souped up dx4.
Would be a fun build to oc.
Reply 19 of 20, by mkarcher
Indeed. Cache chips labelled "WRITE BACK" are fake. No exceptions. The choice between write through and write back cache is performed by the cache controller. The cache memory is exactly the same type in both cases. Memory Chip companies just write their name, the model number, the production date and possibly a batch code on their chip. Only the marketing people that designed fake cache chips got the crazy idea to label them "WRITE BACK".
On the other hand, Cyrix 486 processors having a "Cyrix FasCache" logo, with or without the addition of "write back" are legit. And they all support L1 writeback internally (even the ones not mentioning write back), it's up to the BIOS to enable it and up to the chipset to deal with it, though. If the chipset doesn't support writeback L1 cache coherency protocols, the Cyrix processors run in write-through mode, which is good enough in most cases.
