Super Socket 7 RAM issue
First post, by Bernkastel7734
Hello,
I'm having a problem with SS7 motherboard: MVP3BS7
(https://www.ultimateretro.net/en/motherboards/6602)
I was using it for a while to test many ISA/PCI/AGP graphics cards. It worked fine, with no problems but after some time I started to get black screen all the time. Used a ISA/PCI POST card and it shows the bios stops at C1 which is memory detection.
I was using two 72pin SIMM 16MB sticks and Pentium 133.
Have tried different ram sticks ( both simm and sdram), tried to use different bios version, and still memory detection error.
Any idea what's going on?
Reply 1 of 6, by Sphere478
A lot of MVP3 boards have a setting for the ram speed usually in jumper form try messing with that also, many MVP3 boards like to use only single-sided memory there are exceptions though
But I would not have expected you to have problems with Simms
Try disabling cache
Sphere's PCB projects.
Reply 2 of 6, by majestyk
Have you checked / replaced the electrolytics in the VRM sections? This mainboard could be affected by the "capacitor-plague" that hit most of the manufactureres in those years.
Reply 3 of 6, by Bernkastel7734
I can see what the problem can be. On SDRAM pins where it should be power voltage ( 3,3V I guess) there is only 0,64V
Reply 4 of 6, by Bernkastel7734
I have noticed that my board has got one ripped coil near RAM area
Reply 5 of 6, by Bernkastel7734
So, I have replaced the coil and checked voltages for simm and sdram, both are looking good but still that C1 error
