Reply 60 of 82, by Con 2 botones
- Member
stanwebber wrote on 2022-05-18, 18:39:Con 2 botones wrote on 2022-05-18, 16:46:But I did try an exotic mobile Duron, DHM0950AQS1B. This didn´t work in other two socket A boards of mine, didn´t work on this […]
This didn´t work in other two socket A boards of mine, didn´t work on this Iwill either.
I suspect it is in non working condition though, it is a little"biten" on its die lower-right corner:that's a huge bite. it looks even worse zoomed in. there's no hope going that deep into the core.
Got it very inexpensive, sold untested.
I would like to test a mobile Duron or Palomino on the board to see if those are supported.
As you said, this one looks defunct.
